Re: EL HEMINO Progress
[Re: BDW]
#3259479
09/23/24 06:20 AM
09/23/24 06:20 AM
Posts: 3,893 Smyrna, South Carolina
STEFF
How's the body mount, rubber biscuits? I'm guessing you upgrade that weak spot? Factory rubber mounts have been replaced with aluminum mounts.
[Re: BDW]
#3260255
09/26/24 03:42 PM
09/26/24 03:42 PM
Posts: 12,428 Looking for a way out of Middl...
IMGTX
I was kinda thinking the same thing. The work looks great but the rear frame rails look pretty thin after being cut over the wheel arch OR maybe I am over thinking it?
[Re: IMGTX]
#3261859
10/04/24 06:06 AM
10/04/24 06:06 AM
STEFF
I was kinda thinking the same thing. The work looks great but the rear frame rails look pretty thin after being cut over the wheel arch OR maybe I am over thinking it? Even narrowed, the frame rails are fine. It's pretty much what you have to do to fit a tire under a G-body. Plus, once the body gets bolted back onto the chassis, and the roll cage bars get implemented, it's more than strong.
[Re: Bubba]
#3262648
10/07/24 11:22 PM
10/07/24 11:22 PM
Posts: 6,190 Melbourne , Australia
LA360
All of the additional tubing in the rear, even with the notching, it is probably stronger than it was from the factory.
Nice work as always Steff
Alan Jones
[Re: LA360]
#3262675
10/08/24 06:14 AM
10/08/24 06:14 AM
STEFF
Nice work as always Steff Correct. Thanx Alan!!
