I have a voltage problem
#3257931
09/15/24 01:24 PM
09/15/24 01:24 PM
Posts: 149 Missouri
randavis
Missouri
I have AndyF's Toyota alternator conversion on my car. It has been running good for a couple of years. In the last few days, my voltage is sometimes low on startup and won't increase until I increase rpm over about 5,000. At that point, it jumps from 12.6 to 13.7. I have driven the car at the 12.6 rate for several miles and the voltage doesn't drop as I would expect if it wasn't charging (wife in car and she gets nervous when I get on it). It doesn't do it at every startup, but it is starting to get more frequent. I have a volt meter in the car and the Sniper handheld shows the same voltage. They both get voltage from the starter relay. The battery is fully charged as I keep it on a battery minder. I have checked for voltage drop and haven't found any obvious bad connections. This has me baffeled. Other than swapping out the alt, does anyone have any suggestions?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: I have a voltage problem
[Re: randavis]
#3257959
09/15/24 02:59 PM
09/15/24 02:59 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
[Re: randavis]
#3257980
09/15/24 04:32 PM
09/15/24 04:32 PM
Posts: 5,467 So Cal
Sinitro
So Cal
Sounds like the regulator may be going out... Thats one drawback of the the (1) wire system, having the regulator builtin requires changing out the entire alternator...
Just my $0.02...
