Re: Hydraulic press recommendation for home use
[Re: vinnyd76]
#3257887
09/15/24 10:10 AM
09/15/24 10:10 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
i bought a chinesuim 20 ton floor model H frame press from hobo fright many years ago when they opened up a store in the next town over, and at that time it was only a tick over $100.00 if i remember right. it works for anything i have done with it, including bending small strips of 3/8" thick x 1 1/2" steel. 1/4" steel is no problem up to 6" wide. i made fixtures to do this by welding up plates and angle iron pieces. i don't use it much, but it stands ready against the garage wall waiting. i don't know how much they are today, but most likely way more. an air over hydraulic [or maybe it's the other way around ?] press is better, but those are really expensive, and any i have seen advertised for sale look beat, and most need some kind of repair to make usable again. it all boils down to what you have in mind to be using it for, and how much you will be using it. my one buddy bought a chinesium A frame bench model press over 25 years ago to install the front control arm bushings [upper and lower] in his 70 super bee. it's a pretty chintzee 12 ton, bolt together deal, and he didn't pay very much for it, but it did the job he needed it to do with ease. i really don't know how much he has used it since, if at all, so i don't know how it has lasted over the years, or if he still even owns it today. hopefully, others will chime in with their results and experiences.
[Re: moparx]
#3257936
09/15/24 12:37 PM
09/15/24 12:37 PM
Posts: 27,243 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
I, too, have the HF 20-ton and it serves me well. Only thing I've always intended to do is rig up a winch to raise/lower the table.
This handy attachment turns it into a press brake.
[Re: Moparite]
#3257958
09/15/24 01:57 PM
09/15/24 01:57 PM
Posts: 10,682 Rittman Ohio
fourgearsavoy
Rittman Ohio
My Look on marketplace for a decent used one possibly made in USA. I found a used Blackhawk USA made 20 ton press with extra plates for $150. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3257987
09/15/24 04:51 PM
09/15/24 04:51 PM
Posts: 21,802 N.E. OHIO, USA
A12
N.E. OHIO, USA
My Look on marketplace for a decent used one possibly made in USA. I found a used Blackhawk USA made 20 ton press with extra plates for $150. Gus That's what I did Gus and found an engine builder down around Litchfield that had a Made in USA high ton heavy duty press that was well worth what he was asking for it and it came with several two-inch-thick press plates. Heavy duty "H" frame with thick feet or base beams. No comparison to the lightweight "barging pricing" oriental models. Got lucky and hopefully you will too. Marketplace or Craig's List. Mike
[Re: TJP]
#3258100
09/16/24 07:55 AM
09/16/24 07:55 AM
moparx
I, too, have the HF 20-ton and it serves me well. This handy attachment turns it into a press brake. Have one of those, real handy accessory i made one of those, and it really comes in handy. when i bought my chinesium press, there was no such thing as fakebook or market place, or i would have looked there first for a better piece.
[Re: moparx]
#3258111
09/16/24 08:36 AM
09/16/24 08:36 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Harbor freight 20 ton press for me. I Dont use it as much as I thought I would but for the 160.00 it cost it’s worth it.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: pittsburghracer]
#3258158
09/16/24 11:00 AM
09/16/24 11:00 AM
Posts: 11,078 North Dakota
6PakBee
North Dakota
I built mine. Press Plans
#3258198
09/16/24 01:14 PM
09/16/24 01:14 PM
Posts: 22,071 Enjoy life today, It has an ex...
gtx6970
Harbor freight 20 ton press for me. I Don't use it as much as I thought I would but for the 160.00 it cost it’s worth it.
I used to have one of their smaller presses, I bought new when I had my shop. Sold it maybe 6 or 7 years later for almost exactly what I paid for it. I didn't use it much, mainly control arm bushings and Transmission assy work ,,,,,but it sure comes in handy when you need one
Enjoy life today, It has an expiration date
[Re: 6PakBee]
#3258331
09/17/24 10:10 AM
09/17/24 10:10 AM
moparx
way back in the mid to late 1970's, i had a set of plans [still do, and they were free at that time] to build a press. i was all set to do just that, but when the hobo fright opened, it was just way more cost effective to buy their chinesium version over buying the steel necessary, then spend untold hours cutting, welding, drilling holes, painting, then assembling a fabricated press, that one may or may not, only use occasionally. as a fabricator and machinist for almost 50 years during my working career, and still practicing today many, many years after retirement, i still draw up plans and collect others for equipment i would like to build someday. however, i need to keep kickin' for at LEAST another 75+ years, just so i can get half of that stuff done before i croak.............
[Re: moparx]
#3258389
09/17/24 12:54 PM
09/17/24 12:54 PM
A12
N.E. OHIO, USA
way back in the mid to late 1970's, i had a set of plans [still do, and they were free at that time] to build a press. i was all set to do just that, but when the hobo fright opened, it was just way more cost effective to buy their chinesium version over buying the steel necessary, then spend untold hours cutting, welding, drilling holes, painting, then assembling a fabricated press, that one may or may not, only use occasionally. as a fabricator and machinist for almost 50 years during my working career, and still practicing today many, many years after retirement, i still draw up plans and collect others for equipment i would like to build someday. however, i need to keep kickin' for at LEAST another 75+ years, just so i can get half of that stuff done before i croak............. Besides the steel you would buy here to make it would probably have come from......................
[Re: A12]
#3258445
09/17/24 05:59 PM
09/17/24 05:59 PM
Posts: 12,824 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Years ago, there were guys out of the Carolinas would run up and down the East Coast, selling shop equipment that was built down there, out of the back of their pickups. Bought a twenty ton unit from one of them one day. Walked away from him 3 times before I got him down as low as I thought he would go. Don't even remember the price.
Works great to this day. Find one of those for sale somewhere.
[Re: A12]
#3258572
09/18/24 10:36 AM
09/18/24 10:36 AM
moparx
way back in the mid to late 1970's, i had a set of plans [still do, and they were free at that time] to build a press. i was all set to do just that, but when the hobo fright opened, it was just way more cost effective to buy their chinesium version over buying the steel necessary, then spend untold hours cutting, welding, drilling holes, painting, then assembling a fabricated press, that one may or may not, only use occasionally. as a fabricator and machinist for almost 50 years during my working career, and still practicing today many, many years after retirement, i still draw up plans and collect others for equipment i would like to build someday. however, i need to keep kickin' for at LEAST another 75+ years, just so i can get half of that stuff done before i croak............. Besides the steel you would buy here to make it would probably have come from...................... very true, as i have in my stash of "stuff", possibly enough of H and I beam material to build a press, plus more than enough angle iron, strap steel, etc. that i know for sure was produced here and canukiduh. [canada is ok in my book, as i have relatives that live there. i'm just being an a$$. ]
