alignment problem
#325761
05/22/09 02:43 PM
05/22/09 02:43 PM
Posts: 1,629 wilmington,ohio
ohiodemon
wilmington,ohio
hello,my 72 demon will squeal the front tires and pull to the right when going over a small hill in the road. the car tracks straight and tire wear looks very good. what's causing this ? ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: alignment problem
[Re: 68HemiB]
#325763
05/22/09 04:13 PM
05/22/09 04:13 PM
RapidRobert
Give it a good visual inspection(loaded/unloaded)& see if anything jumps out at you & go from there.
[Re: ohiodemon]
#325765
05/22/09 06:17 PM
05/22/09 06:17 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
if front end is ok, have alignment checked, it can go straight and not have tire wear and still be out of alignment ![](/ubbthreads/images/graemlins/boogie.gif)
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
