Alternator #3256832
09/09/24 03:23 PM
09/09/24 03:23 PM
Ambridge, Pa.
rickraw Online content OP
rickraw  Online Content OP
Ambridge, Pa.
I’m looking for a 130 to 140 amp 1 wire alternator that will work with b1 heads with factory brackets, I would appreciate any input thanx.
Re: Alternator [Re: rickraw] #3256840
09/09/24 04:12 PM
09/09/24 04:12 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Tried them all and one company stands out. These charge at idle with all my crap running.
https://www.mechman.com/1963-1985-click-for-different-models/
https://www.mechman.com/universal-custom/
Re: Alternator [Re: Dragula] #3256848
09/09/24 05:15 PM
09/09/24 05:15 PM
Ambridge, Pa.
Ambridge, Pa.
The front oil drain hits the square back alt, I had to grind on the alt to fit. That’s why I’m asking if there’s a 1 wire alt that works with b1 heads.
Re: Alternator [Re: rickraw] #3256849
09/09/24 05:26 PM
09/09/24 05:26 PM
Dragula Offline
Dragula  Offline
Well, I run my alternator off my front plate...Makes it a lot easier to put it where it fits....
Re: Alternator [Re: Dragula] #3256850
09/09/24 05:30 PM
09/09/24 05:30 PM
Ambridge, Pa.
Ambridge, Pa.
Nice install, I can’t do that, vacuum pump is down there.
Re: Alternator [Re: rickraw] #3256851
09/09/24 05:37 PM
09/09/24 05:37 PM
Dragula Offline
Dragula  Offline
High mounted one in my A-body...
Re: Alternator [Re: Dragula] #3256899
09/09/24 10:27 PM
09/09/24 10:27 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Not that it would be that fun to do, but turn some spacers on a lathe to push the entire front drive out 1/2"?
Re: Alternator [Re: rickraw] #3256905
09/09/24 10:55 PM
09/09/24 10:55 PM
I bought and used a Power Master single wire 100 amp on my pump gas Duster with a 400 stroker motor using elephant ears for the front motor mount up work scope
You might want to look closely at using the power steering boss on the driver side of the water pump housing to mount your alternator scope luck
Re: Alternator [Re: Cab_Burge] #3256943
09/10/24 09:39 AM
09/10/24 09:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I've run East Coast Auto Electric ones for years and the only one that failed was in a fire. Thye rebuilt it and got it back to my quickly. I currently have this one on my truck.. BUt I use a low mount Doty kit to mount it. On my 64 with the B1 it is also with a low mount kit. They sell 12 and 16v versions since its a race car I have a 16V
https://www.eastcoastalternator.com/product/16v-160-amp-one-wire-alternator-powder-coated/
Re: Alternator [Re: Al_Alguire] #3256950
09/10/24 10:08 AM
09/10/24 10:08 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Another solution would be to run a front drive mandrel so you can do just about anything you want for pulley arrangement and offset.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Alternator [Re: turbobitt] #3257709
09/14/24 08:21 AM
09/14/24 08:21 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Looking back to your picture, I think you could retap the head and go deeper with the pipe thread to screw that fitting in right to the shoulder, seal it with hardset gasoila thread sealant. If you could get a elbow with pipe thread
on the outlet, you could skim the back side of the 90 to get a smidge more, then move the AN fitting down below the alternator.
