Charger hood turn signal wiring #3255135
09/01/24 03:27 PM
09/01/24 03:27 PM
Abilene, Texas
fastmark Online content OP
fastmark  Online Content OP
Abilene, Texas
I need just the wiring for the hood turn signals for my 70 Charger. The kits I’ve seen include reproduction lenses. I don’t need those. Anyone know where I can get just the wiring?
Re: Charger hood turn signal wiring [Re: fastmark] #3255309
09/02/24 11:11 AM
09/02/24 11:11 AM
moparx Offline
moparx  Offline
this won't be of much [if any] help to you, but i needed this wiring as well.
fortunately, i had a bunch of good harnesses in my stash of "stuff", and they contained the correct colors, as well as gauge size, [possibly one size larger] and the wire was long enough to be cut to length.
as i had several of the correct terminal housings to mate with the housing on the main harness, i needed to just install the proper terminals in the respective housing, and i had a new hood wiring harness.
all it cost me was the time to unwrap the old harness[es] and the couple of terminal ends, then assemble the harness.
the "fun" part was fishing the harness through the hood channel[s] the original harness was routed through.
that took several attempts with bent up pieces of house wiring and mig wire to fish up through the hood channel[s] before i had enough to securely tape the new signal light harness to, and pull it down through the hood.
beer
Re: Charger hood turn signal wiring [Re: moparx] #3255332
09/02/24 12:48 PM
09/02/24 12:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thin - say, .030 or so - welding wire is good for fishing wiring through areas like Charger hoods.
A bit of electrical tape or a small hook in the end, and pull carefully.
Nice thing about that specific harness is most of it is hidden, so it's not hard to fabricate if you have a couple short lengths with proper (visible) connectors.
Re: Charger hood turn signal wiring [Re: fastmark] #3255780
09/04/24 12:23 PM
09/04/24 12:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Classic Industries for assorted 70 Charger hood turn signal harness wiring only
Re: Charger hood turn signal wiring [Re: DAYCLONA] #3255802
09/04/24 02:29 PM
09/04/24 02:29 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Mark,
Contact Krusin Moons for your new TS wiring kit.
From their website:
Turn Signal Indicator Wires Used on 60's and early 70's Mopars. Wire can be ordered complete or with the crimped bullet end separate. If ordered separate , crimped bullet end and heat shrink can be installed once wire is inserted into indicator. Custom Fit for your car. $35.00/set+S/H
Dennis J. Mullen
534 Mars St.
Johnstown, PA 15905
(814)-255-7993
Email Address: krznmoon@atlanticbb.net
Web Site www.Krusinmoons.com
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Charger hood turn signal wiring [Re: 70gtx440dana] #3255823
09/04/24 03:54 PM
09/04/24 03:54 PM
Abilene, Texas
Abilene, Texas
Ok. Thanks guys. I’ll check it out.
Re: Charger hood turn signal wiring [Re: fastmark] #3255936
09/05/24 11:13 AM
09/05/24 11:13 AM
moparx Offline
moparx  Offline
please let us know how this turns out if you would.
beer
Re: Charger hood turn signal wiring [Re: moparx] #3256121
09/06/24 08:45 AM
09/06/24 08:45 AM
Abilene, Texas
Abilene, Texas
I looked at all the options and most did not have the complete wiring that I needed exactly like the factory had. One company was out of stock for just the secondary wiring but I need from the sockets to the firewall. I found one on Mopar Plus for $109 with the lenses and bulbs. Their kit will work if you only have just the bezels. It probably the same one the YO has for sale. So I bought it. It does not include the 3 black plastic clips that hold the wiring so I bought that from eBay.
