Oil pressure #3255787
09/04/24 01:16 PM
09/04/24 01:16 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
There are three ports above the oil filter. I believe the one facing forward is the oil pressure sensor port. The bottom one on the side is for oil temp. The question is can I use one of the side ports for the oil pressure sensor going to my Dakota Digital gauges?
Re: Oil pressure [Re: Dabee] #3255820
09/04/24 03:38 PM
09/04/24 03:38 PM
K
Kiddart Offline
Kiddart  Offline
K
I used the one on the front of motor
Thank you
Kiddart
Re: Oil pressure [Re: Kiddart] #3255832
09/04/24 04:58 PM
09/04/24 04:58 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
The front one is being used for the Terminator. I need a second one for the gauges. Guess I could install a T and use the front for both sensors. Would rather use one of the side ports if possible.
Re: Oil pressure [Re: Dabee] #3255848
09/04/24 07:02 PM
09/04/24 07:02 PM
BDW Online content
BDW  Online Content
I moved the factory pressure sensor to the side, you can pull that plug in your pic and use that port.
I was then able to use the large 70 style sensor in the front for my stock gauges.
It's tight, but both temp and pressure fit on the side.
Re: Oil pressure [Re: BDW] #3255863
09/04/24 08:43 PM
09/04/24 08:43 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Thanks, that’s what I was hoping could do.. just wasn’t sure if pressure would be there.
