Re: Question about vacuum filling a vehicle's cooling system
[Re: StrokerPost]
#3255734
09/04/24 06:45 AM
09/04/24 06:45 AM
Posts: 10,128 MN
JERICOGTX
MN
Does not need to be completely empty. We do this on every machine we build new at work, and i refill them, when I do repair work, the same way. Suck the air out, then open the valve, and let it fill. I usually do them twice to make sure the system, is completely full.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3255853
09/04/24 06:41 PM
09/04/24 06:41 PM
Posts: 6,852 Missouri
StrokerPost
Missouri
Does not need to be completely empty. We do this on every machine we build new at work, and i refill them, when I do repair work, the same way. Suck the air out, then open the valve, and let it fill. I usually do them twice to make sure the system, is completely full. Thanks Jerico for the input. So you say you do it a 2nd time to make sure it's full and no air in it, to be clear that's with it full or nearly full correct? PS, I keep wanting to call you Jeff, is that right? It's been some years since I talked to you lol
[Re: StrokerPost]
#3255875
09/04/24 09:18 PM
09/04/24 09:18 PM
Posts: 4,382 Morrow, OH
markz528
Morrow, OH
So just went through this on my daughter's 2014 escape with a 2.5L. I believe yours's is a different body design so may be different than this one, but in order to use a vacuum filler you need to take the cowl off - absolutely no room. I did buy the vacuum filler, but elected to do it old school. I have a cooling system funnel kit, and using several 45's I was just able to make the funnel kit work without removing the cowl.
Worked out just fine. Burped many times, level went up, level went down and then all good. Took it on a 1200 mile trip and went down just a cupful ion the overflow tank, But the radiator is not higher than the overflow tank in this car.
So it was not hard to fill this 2.5L engine.
[Re: JERICOGTX]
#3255918
09/05/24 08:52 AM
09/05/24 08:52 AM
Posts: 6,646 nowhere
Sniper
nowhere
Does not need to be completely empty. We do this on every machine we build new at work, and i refill them, when I do repair work, the same way. Suck the air out, then open the valve, and let it fill. I usually do them twice to make sure the system, is completely full. Agreed, this is what I do on my 51 Plymouth.
[Re: StrokerPost]
#3255926
09/05/24 09:32 AM
09/05/24 09:32 AM
Posts: 10,128 MN
JERICOGTX
MN
Does not need to be completely empty. We do this on every machine we build new at work, and i refill them, when I do repair work, the same way. Suck the air out, then open the valve, and let it fill. I usually do them twice to make sure the system, is completely full. Thanks Jerico for the input. So you say you do it a 2nd time to make sure it's full and no air in it, to be clear that's with it full or nearly full correct? PS, I keep wanting to call you Jeff, is that right? It's been some years since I talked to you lol Correct,and correct. As for coolant coming out during the second fill, I just wrap a rag around the "exhaust" of the filler, and it does spray every where then.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3256076
09/05/24 09:19 PM
09/05/24 09:19 PM
StrokerPost
Missouri
Does not need to be completely empty. We do this on every machine we build new at work, and i refill them, when I do repair work, the same way. Suck the air out, then open the valve, and let it fill. I usually do them twice to make sure the system, is completely full. Thanks Jerico for the input. So you say you do it a 2nd time to make sure it's full and no air in it, to be clear that's with it full or nearly full correct? PS, I keep wanting to call you Jeff, is that right? It's been some years since I talked to you lol Correct,and correct. As for coolant coming out during the second fill, I just wrap a rag around the "exhaust" of the filler, and it does spray every where then. Ok, thanks again to everyone, got it handled
