Wiring a Street/Strip Car Q: (and maybe a build thread) #3235885
05/31/24 11:32 AM
05/31/24 11:32 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So I have been laying low and collecting parts this year because it has not turned out how I expected, and I am all jammed up with life type stuff right now. Only the Lord above knows if I will have this all running this year...
I ordered all the right crimpers and such and bought a wire labler to do this right. I bought a Leash street/strip relay board and an appropriate harness from Vincent performance.
My question on race car wiring is, I have a switch panel with about 11 wires on it, and an ignition box with 11 wires on it, and I bought 12pin connectors from Painless. I also have a ton of the weather pack connectors. None of them, to me, are any good for any real amperage draw...But should I use the Painless connectors, or should I use the wire strips with screws and spade connectors? I am worried the pins may move around some in the multi connectors and not have positive contact like the screws and spade connectors would...Thoughts?
https://www.summitracing.com/parts/prf-40012?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+P&utm_term=4581939832705897&utm_content=GSAPI+5ba28fd9454f1
Or
https://www.summitracing.com/parts/rfw-tb10
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3235907
05/31/24 12:26 PM
05/31/24 12:26 PM
moparx Offline
moparx  Offline
i have wired several vehicles using the screw connectors you show. they are available in 4,6,8, 10, and 12 place lengths. [at least that's what i have on my shelf] they have taken up to 65 amps without any trouble. i believe they are also available with a snap on clear cover that contains labels to tell which item is connected at each terminal. [which my terminal blocks do not have]
however, instead of using open spade terminals, i use the ring style that fit the screw size.
i believe the rings give a better connection.
just my opinion. your mileage will vary.
beer
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: moparx] #3235929
05/31/24 01:37 PM
05/31/24 01:37 PM
Dragula Offline OP
Dragula  Offline OP
Would you use the 12 pin connectors though? None of the circuits I am running thru them will be any real amperage, but I do not feel they are up to automotive standards.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236056
06/01/24 08:56 AM
06/01/24 08:56 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Why do you feel that the 12 pin connector built by an automotive wiring company isn't up to automotive standards?
Personally I would use it if I were wiring a car and want to be able to disconnect through a firewall or some such
eBay-cdwmotorsports
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236132
06/01/24 02:07 PM
06/01/24 02:07 PM
First thing to consider is if all the wire gauge size are proper for the load that each one is design to carry in that circuit :with a safe margin for occasional higher short term loads like after starting the car up after it has set a long time work scope: twocents
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Cab_Burge] #3236195
06/01/24 07:49 PM
06/01/24 07:49 PM
Dragula Offline OP
Dragula  Offline OP
I am not much of a garage mechanic, but I try and have the tools I need and work on my skills as I go. So this is my attempt at wiring the Cuda the right way after dealing with the mess its been since I got it....Not sure how it will turn out, but there is no turning back now....A nice Dodge Viper would have been so much less work and cheaper in the end.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236224
06/01/24 10:35 PM
06/01/24 10:35 PM
looks like you got a good start on it up wrench bow grin
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236286
06/02/24 12:12 PM
06/02/24 12:12 PM
moparx Offline
moparx  Offline
but not as much "fun", and you would have a "fuller" head of hair......... biggrin
it looks like you are starting off on the right track, and are using quality components. up
beer
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: moparx] #3236301
06/02/24 12:40 PM
06/02/24 12:40 PM
Dragula Offline OP
Dragula  Offline OP
Yeah, now the tough part begins....
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236437
06/03/24 05:33 AM
06/03/24 05:33 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Or
Looks real nice to me. I like to use Vincent for what he has in stock, good guy.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3236483
06/03/24 10:40 AM
06/03/24 10:40 AM
moparx Offline
moparx  Offline
i have several new 4 and 6 screw terminal blocks [like you have shown a picture of the 8 or 10 terminals] on my shelf i will never use, so if you would like a few, pm me your mailing address, and i will send them out gratis, just so someone can get some use out of them.
beer
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: moparx] #3255159
09/01/24 04:15 PM
09/01/24 04:15 PM
Dragula Offline OP
Dragula  Offline OP
Well, I am feeling better and I am starting to pull the wiring out of the car to get it all stripped down, so I can start putting in the new harness...I have a bruise on my chest from the roll bar from leaning on it trying to reach all the stuff in there...Wish I was younger and skinnier...I did get some quotes to have someone else do this, and I was almost shocked. So like most things, that's about all I needed to get my [censored] in gear to give this a try....
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3255204
09/01/24 07:39 PM
09/01/24 07:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Can get a couple grand in a simple deal quick, or more, depending on what parts and pieces you use, how much stuff is in the car and how much stuff needs to be made.
And you can buy some crap at Autozone and make it run. At least for awhile. Just depends.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3255324
09/02/24 10:51 AM
09/02/24 10:51 AM
moparx Offline
moparx  Offline
i have been leaning into the trunk of my charger, cleaning up the floor crust and applying raptor bed lining, followed by a cinnamon color rustoleum that closely matches the color of the car, and i can relate to the bruising and discomfort you describe ! ["gettin' old ain't for sissies ! ...... or the most often used other descriptive word. biggrin]
i sprayed the cinnamon color over the raptor lining before it set up, and it appears that my method worked, because after about a week, it is pretty tough to get a mark in the color, unless i try to really hard.
my offer still stands if you need some of those screw junction blocks for your new wiring.
beer
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: moparx] #3255383
09/02/24 03:17 PM
09/02/24 03:17 PM
Dragula Offline OP
Dragula  Offline OP
Might have bit off a little too much on this one....
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3255384
09/02/24 03:20 PM
09/02/24 03:20 PM
Dragula Offline OP
Dragula  Offline OP
fun...Thinning it down...But still have not got to the main switch panel.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3255428
09/02/24 07:05 PM
09/02/24 07:05 PM
AndyF Offline
AndyF  Offline
The best stuff to use for amperage is the newer Metripack connectors. Metripack 150 is the most common for lower amp stuff but you can step up to the Metripack 250 for higher amps. WeatherPack gets really bulky for the bigger connectors.
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: AndyF] #3255491
09/02/24 11:27 PM
09/02/24 11:27 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
You like those better the the Deutsch connectors?
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: mopowers] #3255548
09/03/24 10:52 AM
09/03/24 10:52 AM
Dragula Offline OP
Dragula  Offline OP
Honestly, I have never used the Deutsch connectors. Call it lack of experience. I am not liking the style I have that much. I think they are called Weather Pack...They are junky...
https://www.summitracing.com/parts/sum-900404
Re: Wiring a Race Car Q: (and maybe a build thread) [Re: Dragula] #3255779
09/04/24 11:20 AM
09/04/24 11:20 AM
moparx Offline
moparx  Offline
those are quite bulky, and i believe you are correct, weather pack.
i have robbed newer style connectors from late model mopar wiring harnesses, then bought new terminal ends [the deutsch style] and used those connectors on several wiring harnesses i have assembled over the years.
just make sure to use a quality crimping tool, and not one of those parts store specials that come with a 10,000 piece terminal kit for $9.99..........
beer
