For Sale/ Wanted - Elephant Hemi Engines - 3rd Quarter
#3241608
06/30/24 08:09 PM
06/30/24 08:09 PM
Posts: 15,633 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale/ Wanted - Elephant Hemi Engines - 3rd Quarter
[Re: moparts]
#3244480
07/14/24 04:40 PM
07/14/24 04:40 PM
Posts: 6,686 sw chicago
RAH
sw chicago
WANTED 1968-9 Street Hemi parts left over from restoration. Power steering hose 2537 980 Hemi carbs 4430,4431, &4432. exhaust manifolds Bob Horman
Vintage Hemi Intake and Carbs
[Re: moparts]
#3247862
07/28/24 12:28 PM
07/28/24 12:28 PM
Posts: 448 montana
BANDIT
montana
Weiand tunnel ram and Holley carbs for Hemi. The numbers on manifold appear to correlate with Direct Connection catalog from the 80's. Carbs are old 3 circuit Dominators, approx same era. Manifold has been opened up for air flow. Bolt holes look good. Pulled all bowls off, no oxidation inside, nice and clean. Part numbers are in pictures. $1500.00 OBO. Thanks Moparts!
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 1980 Plymouth Arrow 572 Hemi. 242" Mullis Dragster. 6.90@ 200mph
[Re: moparts]
#3248919
08/02/24 04:15 AM
08/02/24 04:15 AM
Posts: 229 New Jersey
938-DAN
New Jersey
** SOLD **
426 Hemi intake manifold. This is one of the newer replacement manifolds not a vintage original. I believe this was installed and used for a short time but very clean with no damage or modifications. Located in southern New Jersey. Price is $600.00. Buyer pays shipping, free local pickup or free delivery to the Mopar Nationals. For questions or to see additional pictures message me here or email hemicarbguy@gmail.com .
Thank you.
** SOLD THANK YOU **
[Re: moparts]
#3248920
08/02/24 04:26 AM
08/02/24 04:26 AM
938-DAN
New Jersey
** SOLD **
E Body 426 Hemi air breather assembly; shaker baseplate, lid and filter element. These are reproduction pieces. Baseplate was modified for use with air conditioning. These pieces were used for a short time but are still in good condition. Located in southern New Jersey. Price is $500.00 for the three pieces. Buyer pays shipping, free local pickup or free delivery to the Mopar Nationals. For questions or to see additional pictures message me here or email hemicarbguy@gmail.com .
Thank you.
[Re: 70HemiGTX]
#3250773
08/11/24 12:48 PM
08/11/24 12:48 PM
Posts: 868 Missouri
galen
Missouri
For sale 16 bolt Ray Barton dominator intake. New 550$ plus shipping.
[Re: dsd70bee]
#3252075
08/17/24 02:04 PM
08/17/24 02:04 PM
Posts: 12,521 Taxes & Virus's R-US, NY
Dragula
For sale Hemi Block $5800 PM me here, or call me at 716-830-1258 or email me at Dragula426@gmail.com
Callies Hemi Iron block
Slightly used, nothing wrong with it. Could use a final hone for cross hatch, but all is good.
Currently painted orange
Had this in my Cuda as a 605 a couple years back, hurt a rod bearing and went and used another block
Block has a 4.500 bore, and is clearance for a 4.75 stroke.
I have a set of Diamond pistons that can go with it for extra. They are 4.503 or there abouts. They are also for a 4.75 stroke and a perfect fit with a hone touch up.
1970 426 Hemi
[Re: moparts]
#3253751
08/25/24 07:25 PM
08/25/24 07:25 PM
xx29
For sale: 1970 426 Hemi block, has cracks on main bearing saddle areas, no VIN on the block, standard bore. 1970 Hemi heads, with valves and springs, block and heads have been O-ringed, Hemi crankshaft, fresh 10/30 grind and polished by legendary Henry Velasco, set of stock Hemi rods(needs resized), Hemi rocker arm set up, Hemi oilpan. Located in Palmdale, CA. $11500. Price negotiable after you have inspected the parts. Pictures available upon request, not able to load pictures here for some reason. Email: ebodycab@msn.com. Phone: 818-426-8685.
1970-71 Hemi valve covers
[Re: moparts]
#3255028
09/01/24 02:22 AM
09/01/24 02:22 AM
xx29
For sale: 1pr original 1970-71 Hemi black wrinkle valve covers, $2500. Close up pictures available upon request. Email: ebodycab@msn.com. Phone: 818-426-8685
Re: Hemi
[Re: xx29]
#3255379
09/02/24 03:05 PM
09/02/24 03:05 PM
Dragula
605 Hemi for sale...$35k negotiable. (716) 830-1258 or PM here or email me at Dragula426@gmail.com
Has 10-15min run time on it since built. Not even broke in yet. Hemi with 11:1 built by Ron Farley New Comp street friendly roller cam .704 lift Spray bars for the valve springs were added to this build New roller lifters, forget what brand Reduced valve spring pressure from what I normally run to better street it Custom upper rocker & valve spring oiling to help keep eveything alive on the street Brand new Callies block, I have two and put my rotating assembly and heads in the new block. Block is internally coated in glyptol to promote oil drain back Has a 12 quart custom pan with AN16 pick up Milidon pump and cover Indy Hipo big valve heads, flow sheets available on request. Indy 426-3 big 4500 intake ported by me Sniper 4500 efi system good to 1200hp, starts and runs like a nice mild street car in all weather. Indy valve covers Mezeire big water pump
