1993 Cummins – rubber tip missing on fuel shut-off solenoid #3255092
09/01/24 10:52 AM
09/01/24 10:52 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, on my 93 Cummins, it wasn't shutting off when I turned off the key. So I removed the fuel shut off solenoid and found that the rubber tip was missing. I put in a new fuel shut-off solenoid and now it starts and shuts off as it should.
My question is do I need to be concerned about where the disintegrated rubber tip from the FSS ended up? Could it be plugging up something inside the pump or injectors? Do I need to disassemble stuff and clean it out?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 1993 Cummins – rubber tip missing on fuel shut-off solenoid [Re: Hemi_Joel] #3255196
09/01/24 07:18 PM
09/01/24 07:18 PM
Minnesota
Minnesota
Upon further inspection, the rubber tip was found intact and removed. Therefore, this request for information is hereby cancelled.
