dash switch pad #3254139
08/27/24 04:39 PM
08/27/24 04:39 PM
kentucky
b body idiot Offline OP
kentucky
Working on a 69 Road Runner trying to remove the switch panel below the gauge cluster can get the right side out but the left side is not coming out from behind the lower dash pads any short cuts or ideas from prrevious
experience hate to tear up the dash pad.Thanks Mike
Re: dash switch pad [Re: b body idiot] #3254140
08/27/24 04:51 PM
08/27/24 04:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The cage for dimmer switch-wheel is usually the culprit. It's a pain in the butt.
Sometimes - seems to depend on the pad - you can kind of rotate the switch panel out, top first.
There have been a couple where I had to feel around behind everything & unscrew the Phillips-head screws at attach the dimmer assy to the switch panel.
The other fun deal is that those dimmers are prone to corrosion and failure.
Re: dash switch pad [Re: topside] #3254480
08/29/24 08:01 AM
08/29/24 08:01 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I recommend taking gauges completely out and remove switches. This makes it easier to remove. Also, there is s phillips screw in upper LH corner behind gauges that holds pad to frame. This is not an easy job...the vinyl shrinks and therefore the cast switch panel is very difficult to remove and install. If you only want the switch panel out and not the gauges. As suggested above remove switches from back side. The dimmer, headlight and wiper switches can cause complications. Best of luck.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: dash switch pad [Re: 70gtx440dana] #3254773
08/30/24 02:24 PM
08/30/24 02:24 PM
kentucky
kentucky
Thanks I got my service manual out did it the way manual took awhile but got it taken care of
