I am looking for a measurement #3252937
08/21/24 08:26 PM
08/21/24 08:26 PM
Capital of Narcissism
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
I can't get to my A body to measure the car for myself.
It would be a lot easier measure if the TB is removed.
What i need is the number of radial degrees, or two sides of the triangle to calculate the degrees.
What I am searching for is the amount the LCA rotates from full jounce to full compression fully against the LCA bumper.
I am not in a hurry
I am guessing 15?Degrees, but a guess here doesn't cut it.
This helps make sure the TB's are not over stressed or how much they are stressed.
Thanks for any help.
"absence of evidence does not equate to evidence of absence of effect."
Re: I am looking for a measurement [Re: jcc] #3253002
08/22/24 07:08 AM
08/22/24 07:08 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
So you're asking for the clocking of the torsion bar ends? That varies by bar diameter.
Or are you asking for a wheel travel dimension? Though I don't see how this can help determine bar fatigue.
Angry white pureblood male
Re: I am looking for a measurement [Re: ruderunner] #3253046
08/22/24 10:09 AM
08/22/24 10:09 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
I am looking for the total amount an A body TB rotates in degrees with full possible wheel travel.
Clocking is not a factor here,
In calculating stress loading of the bar, it requires a number for the amount of degrees the bar twists.
