68 Charger interior color questions #3251981
08/17/24 06:08 AM
08/17/24 06:08 AM
Netherlands
72Challenger Offline OP
Netherlands
Hey all. About the first time posting in the resto forum but looks like I need some help here.
Friend of my has bought a 68 Charger and likes to restore it as original as possible. The fender tag contains a bunch of easy codes like power brakes etc. but what I was wondering about the interior...
3rd line reads 50 8 1 C6W PP1 W
I come up with something like Charger trim grade, bucket seats, white and white upper door frame color.
Does this sounds correct?
And what all is white then?
Vinyl covers, headliner, door panels, carpet, dash frame, upper door panels, kickpanels etc.
Any input appreciated?
Re: 68 Charger interior color questions [Re: 72Challenger] #3251982
08/17/24 06:11 AM
08/17/24 06:11 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
dash, A-pillars, console, carpet, column, steering wheel, seat belts & kick panels are BLACK everything else is WHITE
Re: 68 Charger interior color questions [Re: 6bblgt] #3251991
08/17/24 07:56 AM
08/17/24 07:56 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, mine had a white headliner, seat covers, hinge covers, door & quarter pads and side panel (aka cards), armrests.
Dash, kick panels, carpet, package tray & seat belts were black.
Heel pad in photo above is in wrong place, way too far back.
Base of gas pedal should be just barely inside forward right corner of heel pad.
Kinda tough to cut the hole there, so some guys avoid that.
Re: 68 Charger interior color questions [Re: topside] #3253242
08/23/24 03:22 AM
08/23/24 03:22 AM
Netherlands
Netherlands
Perfect, thanks! Helps me a lot!
Re: 68 Charger interior color questions [Re: 72Challenger] #3253316
08/23/24 11:40 AM
08/23/24 11:40 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
https://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1968/68_Charger0001.jpg
Here is the dealer color chart for 68 Charger. The white in 68 is actually a pearl white. Herb's Parts has a line of interior dye that works good. They have the 68 pearl white if you need to change the color of some things. If changing from black to pearl white, you need to spray the parts white first. Then put the pearl white on top. If you try spraying the pearl white directly over the black, it will turn out silver.
Re: 68 Charger interior color questions [Re: burdar] #3253318
08/23/24 11:45 AM
08/23/24 11:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes, and I should probably have mentioned that - the pearlescence was noticeable on the seats & side panels - I don't recall it on the headliner or plastic.
