when did dodge go to serptine belt system for trucks #3251790
08/16/24 10:43 AM
08/16/24 10:43 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
mainly for the d150 , didnt the d150 trucks/vans still use v-belts up 93 shruggy
Re: when did dodge go to serptine belt system for trucks [Re: theraif] #3251869
08/16/24 01:59 PM
08/16/24 01:59 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
LA=V-belts
Magnum=Serpentine
Re: when did dodge go to serptine belt system for trucks [Re: nuthinbutmopar] #3251895
08/16/24 04:44 PM
08/16/24 04:44 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Not sure when but I wish they wouldn't have
Re: when did dodge go to serptine belt system for trucks [Re: volaredon] #3251923
08/16/24 06:58 PM
08/16/24 06:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Doesn't seem to make much difference with my stuff. The old power steering adjusting bolts were always a pain with the V belt system.
With the serpentine system, how the belts run around the pulleys is the biggest pain, and just for good measures, about every 5 or so years, I'll install a new belt tensioner, The tension spring in them tends to get weak, or sticks and causes the belt does slip and then strange things to happen..
The magnum motors were installed with the beginning of the 93 model year. Across the board, the LA 3.9. or 5.2 was replaced at the beginning of the model year (the LA 5.9 (360) may have held on for another year).
Re: when did dodge go to serptine belt system for trucks [Re: poorboy] #3251990
08/17/24 06:54 AM
08/17/24 06:54 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
This was answered here. It's better to post one question rather then the same question in different places. The first magnum was 1992 with the 318 then 360 in 1993.
Re: when did dodge go to serptine belt system for trucks [Re: Moparite] #3252034
08/17/24 10:54 AM
08/17/24 10:54 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
yes i did as a question on harmonic balancers in the the Q&A section and wasnt getting any hits , the situation i bought a 89 ramcharger i had a mobile mechanic check it out for me and he said it was good to go. before it was shipped they informed me the balancer need replaced i said ok when i receive it it now has a engine vibration so i thought they may have used a 5.9 magnum not a 360 LA balancer their mobile mech. brought up the belt system i know the 5.9 started to be use in 92 and the crank pulley was separate item on the early ones , so i just think its a 318 or 5.9 balancer , i`ll did into it in a few weeks thanks
Re: when did dodge go to serptine belt system for trucks [Re: theraif] #3252060
08/17/24 12:36 PM
08/17/24 12:36 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Questions like this can often be answered by going to RockAuto and searching the belts category for the installations in question.
Re: when did dodge go to serptine belt system for trucks [Re: John_Kunkel] #3252187
08/18/24 09:29 AM
08/18/24 09:29 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
A 89 should be a LA motor, It's possible a magnum was swapped in. Look at the block casting #, If it's either 53006714 or 53006657(318) and 5302006 for the 360 it's a magnum.
