PLASTIC RECHROMERS #3251645
08/15/24 05:11 PM
08/15/24 05:11 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Looking for a source that the members here have used to rechrome exterior trim. ( if there is/are any ).
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: PLASTIC RECHROMERS [Re: Magnumguy] #3251660
08/15/24 06:25 PM
08/15/24 06:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You need replating services for exterior plastic trim?
Re: PLASTIC RECHROMERS [Re: Neil] #3251721
08/16/24 12:17 AM
08/16/24 12:17 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: PLASTIC RECHROMERS [Re: BloFish] #3251774
08/16/24 09:46 AM
08/16/24 09:46 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I use Vacuum Ornametal for all of my interior plastic re-chrome needs. Not sure what you are needing but they may be able to assist.
Vacuum Orna-Metal Co
Plating service in Romulus, Michigan
Address: 11380 Harrison St, Romulus, MI 48174
Hours:
Open ⋅ Closes 4 PM
Phone: (734) 941-9100
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: PLASTIC RECHROMERS [Re: Neil] #3253929
08/26/24 05:53 PM
08/26/24 05:53 PM
S.E.Ohio
S.E.Ohio
Yes, plastic trim around park lenses for my Magnum.
Re: PLASTIC RECHROMERS [Re: Magnumguy] #3254093
08/27/24 12:44 PM
08/27/24 12:44 PM
Kirkland, Washington
Pacnorthcuda Offline
The turn signal frames in 72-74 Cuda’s are “chrome” plastic. It’s a pain. I sent a set to Canada a long time ago…yes vacuum process as you don’t really “plate” them. As a side note, I worked in the PCB (circuit boards) for 11 years…you DO plate plastic in that industry (thru hole plating) and it greatly complicates manufacturing.
Re: PLASTIC RECHROMERS [Re: Pacnorthcuda] #3254263
08/28/24 09:52 AM
08/28/24 09:52 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Vacuum Orna-Metal 👍
Re: PLASTIC RECHROMERS [Re: 340cpe] #3254347
08/28/24 03:44 PM
08/28/24 03:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Something apparently new to the market is a chrome spray from Revell,
Intended for scale models, photos I've seen looked like model kit chrome.
Seem better than the Al-Clad most model-makers use.
No idea how well it withstands UV light, but may be worth a try.
Re: PLASTIC RECHROMERS [Re: topside] #3264163
10/14/24 09:09 PM
10/14/24 09:09 PM
GMP440 Offline
GMP440  Offline
The Revell Spray Chrome is pretty dead on. I've used it and was over impressed.
Re: PLASTIC RECHROMERS [Re: GMP440] #3264166
10/14/24 09:32 PM
10/14/24 09:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Agree - finally used some on a couple of model kits - very near actual chrome plating, I'd say 95%.
Also, it lays down with a flat (no texture) & smooth finish.
Re: PLASTIC RECHROMERS [Re: topside] #3266434
10/25/24 06:32 PM
10/25/24 06:32 PM
S.E.Ohio
S.E.Ohio
Thanks folks!
