Gen II Hemi Camshaft information.
#3250172
08/08/24 08:46 AM
08/08/24 08:46 AM
Posts: 106 Norway
cudaerik
Norway
I'm working on an 505cid Indy Max Gen II Hemi engine with a unknown camshaft that I'm trying to find some information on. I've been told by the previous owner that it supposed to be a camshaft produced by Cam Motion, in the front of the camshaft it's engraved: R2604 and 2705-12. In the back the camshaft is stamped with: 253117 and the cam core is marked 311804 by the distributor gear.
I hope anyone could help out with some info.
Thanks.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Gen II Hemi Camshaft information.
[Re: cudaerik]
#3250174
08/08/24 09:36 AM
08/08/24 09:36 AM
Posts: 1,319 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
