Axle mods for Green Bearings
#3247182
07/25/24 09:50 AM
07/25/24 09:50 AM
Posts: 824 On the open road
Hrtbkr
On the open road
Hi After carefully considering options and based on past experiences, I decided to install green bearings in my Cuda's 8 3/4. I'll probably be swapping pumpkins often, and don't want to remove the spacer blocks from each. Does anyone know how much I need to shave off the ends of the axels? Thanks
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: Axle mods for Green Bearings
[Re: Hrtbkr]
#3247244
07/25/24 02:11 PM
07/25/24 02:11 PM
Posts: 43,691 Bend,OR USA
Cab_Burge
Hi After carefully considering options and based on past experiences, I decided to install green bearings in my Cuda's 8 3/4. I'll probably be swapping pumpkins often, and don't want to remove the spacer blocks from each. Does anyone know how much I need to shave off the ends of the axels? Thanks I've swap to green axle bearing on many A body 8 3/4 and never had any issues with either type of those green bearings, same thing in stock Dana 60 in B and E bodies Stick them in and make sure you have some end play , at least .015 or more
[Re: calrobb2000]
#3247503
07/26/24 05:39 PM
07/26/24 05:39 PM
Cab_Burge
What brand "green" bearing are you buying that don't have the outer snap ring, travel limiting O rings? I've never had to remove anything from any of the rear ends, 8 3/4 or Dana 60 that I converted to the green axles bearings
[Re: Cab_Burge]
#3247573
07/27/24 04:43 AM
07/27/24 04:43 AM
Posts: 10,294 A Red State
SNK-EYZ
A Red State
What he's concerned with is the axles hitting the buttons in the center of the sure-grip and not letting the axles seat all the way in at the outer end flange.
Most people simply remove the buttons, but he doesn't want to do that.
Doing a trial fit of the axles will show if they're going all the way in.
With the green bearings I don't think that there is any in and out play, pretty sure they simply seat.....
Any play felt would likely mean a loose bearing.
[Re: SNK-EYZ]
#3247603
07/27/24 09:03 AM
07/27/24 09:03 AM
Posts: 20,326 Park Forest, IL
slantzilla
Park Forest, IL
IIRC, not removing the center blocks leads to preload sideways on the bearings when you tighten down the axle retainer/backing plates.
If you're dead set on not removing the inner buttons, fit the axles and measure how far they are from seating. Trim axles accordingly.
I know it's not the answer the OP wanted, but when you're trying to do something the hard way.........
[Re: slantzilla]
#3247610
07/27/24 09:24 AM
07/27/24 09:24 AM
Posts: 10,926 North Dakota
6PakBee
North Dakota
I just looked on Dr. Diff's site and here are the installation instructions:
INSTALLATION INSTRUCTIONS:
Remove old bearings Drop the 5 hole retaining plate over the axle shaft Grease the seal on the new bearings Press the bearing tight against the axle flange with the seal facing the axle flange. Press the lock-ring tight against the bearing.
Note: Install the gray foam gasket between the brake backing plate and 5 hole retaining plate.
[Re: 6PakBee]
#3247627
07/27/24 10:44 AM
07/27/24 10:44 AM
Posts: 8,615 fredericksburg,va
cudaman1969
fredericksburg,va
I’m thinking the bearing race is in the same spot as the green bearing so adjust the axels up to the cross pin the same way as the regular bearing. That way it’s not moving in or out. Doesn’t matter where the bearing rides in housing as long as it’s in there enough.
[Re: 71GTX471]
#3247802
07/28/24 09:09 AM
07/28/24 09:09 AM
Posts: 415 Lexington NC
twinscrew698
Lexington NC
Why do they call them GREEN ? That was the name of the factory in Cleveland Ohio They had a patent on them back then.
[Re: cudaman1969]
#3247812
07/28/24 10:22 AM
07/28/24 10:22 AM
Posts: 6,492 nowhere
Sniper
nowhere
I’m thinking the bearing race is in the same spot as the green bearing so adjust the axels up to the cross pin the same way as the regular bearing. That way it’s not moving in or out. Doesn’t matter where the bearing rides in housing as long as it’s in there enough. The green bearings do not use an adjuster therefore you cannot adjust them the same way as the regular bearings. OEM bearings are taper, Greens are ball bearings. Taper bearings can handle side loads much better than ball bearings, you do not want to side load the Greens, therefore either remove the buttons or run OEM taper style bearings. Or have the greens fail prematurely.
[Re: Sniper]
#3247873
07/28/24 01:59 PM
07/28/24 01:59 PM
cudaman1969
fredericksburg,va
I’m thinking the bearing race is in the same spot as the green bearing so adjust the axels up to the cross pin the same way as the regular bearing. That way it’s not moving in or out. Doesn’t matter where the bearing rides in housing as long as it’s in there enough. The green bearings do not use an adjuster therefore you cannot adjust them the same way as the regular bearings. OEM bearings are taper, Greens are ball bearings. Taper bearings can handle side loads much better than ball bearings, you do not want to side load the Greens, therefore either remove the buttons or run OEM taper style bearings. Or have the greens fail prematurely. All that I know, but you can use the adjusters to put the axels in same position. Those bearings-axels will have side loads o matter how they’re held in. Personally I’ll use the tapered factory bearing for any street car.
[Re: cudaman1969]
#3247890
07/28/24 03:08 PM
07/28/24 03:08 PM
Sniper
nowhere
[Re: Sniper]
#3247934
07/28/24 06:17 PM
07/28/24 06:17 PM
cudaman1969
fredericksburg,va
I’m thinking the bearing race is in the same spot as the green bearing so adjust the axels up to the cross pin the same way as the regular bearing. That way it’s not moving in or out. Doesn’t matter where the bearing rides in housing as long as it’s in there enough. The green bearings do not use an adjuster therefore you cannot adjust them the same way as the regular bearings. OEM bearings are taper, Greens are ball bearings. Taper bearings can handle side loads much better than ball bearings, you do not want to side load the Greens, therefore either remove the buttons or run OEM taper style bearings. Or have the greens fail prematurely. All that I know, but you can use the adjusters to put the axels in same position. Those bearings-axels will have side loads o matter how they’re held in. Personally I’ll use the tapered factory bearing for any street car. Yes it can! To hold the axel bearing from MOVING IF it has no snap ring and no flange to bolt it to the end of housand. Extra safety factor. I’ve seen some early ones where the flange came off the bearing allowing it to move. I’m sure the new ones are made better to not have that problem. One bearing set I have is from the mid 70s, other than welding the retainer to the bearing I could use the adjuster and pin in the carrier. A good chance they’ll sit on shelf forever at this point.
[Re: John_Kunkel]
#3248666
07/31/24 06:50 PM
07/31/24 06:50 PM
cudaman1969
fredericksburg,va
Thanks for setting it straight, Cass. Straight? I just checked MY green bearings, the flange is off and they WILL work with adjusters and non adjuster flanges. Imagine that. Never say never.
[Re: 6PakBee]
#3248834
08/01/24 04:44 PM
08/01/24 04:44 PM
SNK-EYZ
A Red State
I'm confused. Is the concern that the axles will contact the thrust buttons in a Power-Lock differential and prematurely wear out the Green bearings? Is the recommendation to remove the thrust buttons? What do you do with an open differential? Is the recommendation being made to shorten the axles by the thickness of the thrust button head? That's exactly what the original poster wanted to know. He doesn't want to remove the thrust spacers/buttons for whatever reason. He wants to know exactly how much to remove from the inner end of the axle. He also doesn't want the axles contacting the thrust spacers so it won't cause the axle bearings to wear out from having a side load that they weren't intended to have. IMO he's probably overthinking it all....
