Page 3 of 4 1 2 3 4
2020 Featherlite 4410 24 foot enclosed hauler [Re: Azzkikrcuda] #3247286
07/25/24 04:29 PM
07/25/24 04:29 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
No longer racing unfortunately, selling the enclosed trailer. Darn near new, very little use. New today this trailer retails for $54K from Featherlite asking $42K OBO . Willing to assist with delivery.
2020 Featherlite 4410 8.5 x 24 Car / Racing Trailer with rear ramp door
Upgraded with: lined walls & ceiling
upper and lower cabinets
30 Amp motorbase
Aluminum wheels
in addition to the many standard features listed below:
OVERVIEW
Featherlite enclosed bumper pull car trailer Model 4410 offers functionality, durability and value for custom car owners and racers. Featherlite's newest car hauler design features a spread axle, rear spoiler and flat nose. This car trailer, available in lengths of 20', 24' or 28', has a rear ramp and camper door standard to make accessing your cargo easy in this great looking, durable car trailer. While options are more limited on the Model 4410.
HIGHLIGHTS
Lengths of 24'
Width of 8'6"
Flat nose & spread axle design
Aluminum Floor Standard
Rear ramp with cable assist
Inside height of 7'0"
Sleek Rivetless Design
SPECS & FEATURES
Model: 4410
Hitch Type: Bumper pull
Wall to Wall Width: 99" (rear opening width = 94 1/4")
Fender to Fender Width: 82"
Inside Height: 7'0"
Loading Height: 20"
Axles: Two rubber torsion 6000# axles with electric brakes
Tire/Rim: 16" 6-hole silver aluminum wheels with Goodyear ST235/80R16 Load Range E tires (Qty: 4)
Tie Downs: Stainless steel swivel "D" ring tie downs (Qty: 4)
Floor: Smooth extruded aluminum floor
Side Door: 42" heavy-duty 2" double sealed door on curbside
Ramp: Full height & width rear ramp with cable assist, pressure latches, treadplate & vinyl hinge cover
Coupler: 2 5/16" coupler; Crank type jack with wheel
Exterior: White exterior sheets; Flat nose with stainless steel vertical & center panel; Spread axle design with drop skirt and fenderettes; Polished aluminum cast corners
Exterior Lighting: Rear spoiler with load light; Clear LED clearance lights; Slimline LED stop/turn lights (Qty: 4)
Interior Lighting: 6 Surface-mount LED dome lights with switch inside
36" beavertail
Spare tire carrier
2- 14" x 14" crank up roof vents
Skid plate
Custom Winch
Hellcat oil pump [Re: Swingin70] #3247681
07/27/24 02:43 PM
07/27/24 02:43 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Mopar Hellcat oil pump.
New in packaging. Only mocked up on engine.
$130 shipped.
PM me here. Located in NW Indiana
SOLD!
D.S.S. 6.4 HEMI FORGED PISTONS [Re: Swingin70] #3247684
07/27/24 02:51 PM
07/27/24 02:51 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
D.S.S. 6.4 GEN III HEMI Pistons, pins and ringset.
Forged 2618 alloy, 4.100 bore, 1.210 compression height, .927 pins.
For .010 6.4. Good alloy for boost or nitrous.
New in packaging.
$900 shipped
PM me here. Located in NW Indiana.
MSD 383 distributor [Re: moparts] #3247728
07/27/24 05:55 PM
07/27/24 05:55 PM
Yakima, WA
K
kevinlc Offline
kevinlc  Offline
K
Yakima, WA
Used but in excellent condition is a distributor for the 383/400 mopar. This one is locked out for use with a crank trigger.
Part number is 8545. 300.00 plus shipping.
AVO shocks [Re: moparts] #3247731
07/27/24 06:07 PM
07/27/24 06:07 PM
Yakima, WA
K
kevinlc Offline
kevinlc  Offline
K
Yakima, WA
AVO single adjustable shocks. shocks are 12 inches in length. One is 130lbs and the other is 125lbs. Don’t know which ones. Comes with billet lower mounts. 200.00 plus shipping.
Goodyear drag radials [Re: moparts] #3247735
07/27/24 06:17 PM
07/27/24 06:17 PM
Yakima, WA
K
kevinlc Offline
kevinlc  Offline
K
Yakima, WA
Purchased in November 2022 and made two passes in 2023. Switched back to my bias tires. These are 31/13.5/15 drag radial tires. Part number is gdy-4909. $550.00. Local pick up preferred. Located in Yakima WA 98908
Hemi Tunnel Ram and Carbs [Re: moparts] #3248004
07/28/24 10:48 PM
07/28/24 10:48 PM
montana
BANDIT Offline
BANDIT  Offline
montana
For Sale;
Vintage Weiand tunnel ram and carbs. Intake appears to have Direct Connection part numbers on base and top plate. It has some openings cut in it for cooling?? Bolt holes look good.
Carbs are 1050, 3 circuit pieces from approx the same era. Pulled all the bowels off, real clean inside. They do need kits. Part numbers are in pictures. $1500.00 OBO. Call 406-489-3534 for more info and pictures. Thanks for add!
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
1980 Plymouth Arrow 572 Hemi.
242" Mullis Dragster. 6.90@ 200mph
Hooker headers J-Bends - NEW [Re: moparts] #3248073
07/29/24 10:13 AM
07/29/24 10:13 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
NEW Hooker Headers exhaust parts:
#12540 1-5/8" J-bends, 6" x 15", 2.5" radius, 18 gauge.
$18 each -- buy 5 or more at $15 each
NEW Hooker #12560 1-7/8" J-Bends, 6" x 15", 3" radius, 18 gauge.
$20 each--buy 5 or more at $17 each
J-Bends are used for fabricating or modifying existing header tubes for performance and race cars.
Can ship, buyer pays shipping and fees.
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
549" B1 Mopar [Re: GTX5877] #3248978
08/02/24 10:59 AM
08/02/24 10:59 AM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Koffels Place Built
549” B1 Originals ported by Koffels Place
T&D Shaft Rockers
Manley Stainless Valves
Titainium Retainers
KB Block - Never Windowed
13.65:1 Motor
Wiseco Pistons
BME Rods
Moldex Crank
Jesel Belt Drive
Comp Cam - .820 lift
Highly Modified Indy Bathtub Intake for B1 heads
Two edelbrock carbs redone by Damon Kuhn
Aeromotive Pro Stock Reg
Charlies Pan with swinging pick up
Milodon Billet pump
MSD Crank Trigger
~70 Runs on engine
Have all build sheets & dyno sheets from Koffels
HP: 1036 @ 7300
TQ: 813 @ 6200
PM here or call
614-395-2746
Casey FJ
Pick Up in Columbus, OH
Can deliver to Nats or potentially elsewhere within 4 hours of CBUS
$22,500 or best offer
Re: 549" B1 Mopar [Re: Whompin_Wedge] #3249081
08/02/24 07:19 PM
08/02/24 07:19 PM
New Jersey Bada Bing
bremotorsports Offline
Mopar Performance NEW 360 Piston/Ring Set MP Catalog part number P4876978
4.030 Bore 3.58 Stroke
Flat top configuration provides for approximately 10.5 compression.
Going to a different bore size so this set is now available.
900.00 plus shipping. PayPal preferred.
Bill Rolik Enterprises
bremotorsports@verizon.net
201-394-5533 Cell/Text
Photo Archives 33 002.JPG (1256 downloads)
Photo Archives 33 003.JPG (1251 downloads)
Photo Archives 33 004.JPG (1249 downloads)
Photo Archives 33 005.JPG (1251 downloads)
Smal Block Racer Brown STX-21 Solid Flat Tappet Cam - New [Re: bremotorsports] #3249100
08/02/24 08:52 PM
08/02/24 08:52 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new Racer Brown STX-21 solid flat tappet cam. I bought several of these for bracket racing. I am no longer racing so this cam is up for sale. Specs with 1.5 ratio rockers are 560" lift and 272 degrees of duration at 0.050" lift intake and exhaust. LSA is 105 degrees. Great bracket racing cam.
Price is $230 shipped in the lower 45 states.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Howard's Solid Lifter Cam for Mopar Dodge Plymouth Big Block [Re: moparts] #3249113
08/02/24 09:56 PM
08/02/24 09:56 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
For sale is a Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping or I can deliver to the Nats if paid for in advance. I also have a new set of Comp Cams inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $45 for.
https://www.summitracing.com/parts/HRS-CL722322-08
https://www.howardscams.com/mechanical-flat-tappet-camshaft-lifter-kit-1959-1980-chrysler- show contact info -7600-howards-cams
https://www.summitracing.com/parts/cca-973-16
gt340 at yahoo.com
Howard's Cam.JPG (1711 downloads)
Howard's Cam2.JPG (1713 downloads)
Howard's Cam4.JPG (1717 downloads)
Comp Inner Springs2.JPG (1710 downloads)
Small Block I Beam Connecting Rods by Childs & Albert - New [Re: 6PAX] #3249506
08/04/24 08:48 PM
08/04/24 08:48 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of forged I beam connecting rods by Childs & Albert in the original box. American made in the 1990’s. Part number is 340-15B-2. Center to center length is 6.125”. Big end is for small block rod journals of 2.125” and small end is for pins of 0.927”. Weight per rod is ~ 685 grams. See spec card in the pictures.
These are very stout rods, suitable for a high horsepower build.
Price is $850 shipped. I will ship internationally for the added cost.
Valve springs. [Re: Rocket] #3249631
08/05/24 02:38 PM
08/05/24 02:38 PM
Missouri
galen Offline
galen  Offline
Missouri
New in box. Comp 7245-16 dual conical springs, 4669-16 tool steal retainers. 1738-16 spring seats for .570 guide. 7 degree 11/32 locks. springs list 600$. 500$ for all. Isky 9385-16 springs new in box. 200ST-10 retainers. 225$ plus the ride. PM if any questions and I will give phone number.
7245 springs.JPG (1489 downloads)
Barton intake & dominator carb [Re: galen] #3249637
08/05/24 02:52 PM
08/05/24 02:52 PM
Missouri
galen Offline
galen  Offline
Missouri
Ray barton 16 bolt hemi dominator intake. Never ran, no modifications. 550$ you pay shipping. New Holley 1050 red ultra dominator. Has never had fuel in it or tampered with. Not sure if I have original box. 750$ plus ride. PM with questions etc. I will give you my number. Carburetor sold. Still have intake manifold.
barton intake.JPG (1485 downloads)
carb 1.JPG (1483 downloads)
carb 2.JPG (1481 downloads)
426 Hemi Heads [Re: moparts] #3250042
08/07/24 12:24 PM
08/07/24 12:24 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have a set of 426 Hemi Heads for sale. Casting dates are E.31.6 & E.27.6 I was told they came off of a Stock Eliminator race engine, hence the milling on the intake side of the head. I am not a racer, so I do not know. I had them magnafluxed and they are crack free. They are not O-ringed. I have more pictures if needed. email me at: trdeppen"at"comcast.net or pm me here. $3000 local pick-up or buyer pays shipping. Thanks for the ad!
Re: 426 Hemi Heads [Re: 70HemiGTX] #3251351
08/14/24 09:28 AM
08/14/24 09:28 AM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
ATI balancer crank trigger shell. 916612TR. Was ordered to use with Fueltech. 12-1 magnets. I’m running carbs instead so I had to order another shell with 4 magnets. This is brand new. Current price on them $300 plus $100 for the magnets. Plus shipping and tax. I will take $220 shipped lower 48.
Holley 12-846 HP Billet Fuel Pressure Regulator NEWtor "NEW [Re: moparts] #3251465
08/14/24 06:36 PM
08/14/24 06:36 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8AN o-ring outlet. -6AN o-ring return. $175 shipped in the 48 states. PM if interested.
https://www.jegs.com/i/Holley/510/12-846/10002/-1
CSR BB water pump [Re: moparts] #3251890
08/16/24 05:12 PM
08/16/24 05:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a CSR water pump that's been sitting and someone can probably use it. Used but works as it should, comes with hose bibs and inlet. Pm me here or text/call 7 zero 7 9 8 0 - 2 one 67 $200 obo
(NEW) ARC SWITCH CONTROL PANEL #3701 [Re: Al_Alguire] #3252042
08/17/24 12:40 PM
08/17/24 12:40 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
ARC SWITCH CONTROL PANEL #3701 / Part number is provided if you need details.
Brand new never mounted. Forgot I had it.
Accept PayPal or personal check or money order. Your choice.
$225 shipped to your door in the U.S.
PM me if you want it. Thanks Moparts!
"Any fool can know. The point is to understand"
- A. Einstein
Page 3 of 4 1 2 3 4
