Pitman arm fitment ??: #3247186
07/25/24 10:04 AM
07/25/24 10:04 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Should the pitman slide up any further than this ??
Re: Pitman arm fitment ??: [Re: Stanton] #3247232
07/25/24 12:50 PM
07/25/24 12:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine are seated much further than that.
Seems to be 2 spline sizes - 1.250" and 1.125" - for A, B, and E cars - but I've seen a pitman listed (maybe Rock Auto) with a 1.06" size.
Measure what you have and post the info, along with what car.
Re: Pitman arm fitment ??: [Re: topside] #3247240
07/25/24 01:51 PM
07/25/24 01:51 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
69 Road Runner
Its worth pointing out that the car originally had power steering which I swapped for manual. The power steering shaft is the same size as the manual shaft. I still have the factory origfinal pitman arm that, although a different shape, has the same size hole as the one in the photo.
Interestingly, I bought a new nut and washer from Mega Parts last year which I went to use yesterday and its too small. It is 5/8 and the thread on this pitman arm is 7/8 fine.
Re: Pitman arm fitment ??: [Re: Stanton] #3247258
07/25/24 02:46 PM
07/25/24 02:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hmmm...I just did the same swap on my '68 Valiant: PS box had 1.250" shaft, MA was 1.125".
My car may have been switch to PS before I got it, but a pitman for a '68 Valiant from Autozone fit perfectly.
At a glance, the PS arm looked like it would work, but it was in fact too large a spline diameter.
IIRC, C-bodies used a larger shaft.
Re: Pitman arm fitment ??: [Re: topside] #3247329
07/25/24 09:11 PM
07/25/24 09:11 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
My dilemma right now is finding the correct nut and lockwasher. Its thinner than normal - about 1/2 the thickness of a standard nut .
Re: Pitman arm fitment ??: [Re: Stanton] #3247384
07/26/24 08:26 AM
07/26/24 08:26 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
and when tightened ends up flush with the stud. That will give you a better overall view of the engagement.
