taping intake #3247142
07/25/24 12:05 AM
07/25/24 12:05 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I need to drill and tap a 1/8 hole in my alumni intake for a water temp senor right in the front under the water flange there is a thick enough area to do this I just looking for some advice before I do it. The do's and donts better to ask then be sorry . THANKS
Re: taping intake [Re: dragon] #3247144
07/25/24 02:00 AM
07/25/24 02:00 AM
I wouldn't risk drilling and taping for that sender in such a thin spot tsk twocents
How about having an adapter fitting welded in for the sender somewhere near where you want if work scope luck wrench shruggy
Re: taping intake [Re: Cab_Burge] #3247148
07/25/24 02:36 AM
07/25/24 02:36 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Will a spacer work?
Kevin
Re: taping intake [Re: Twostick] #3247151
07/25/24 05:15 AM
07/25/24 05:15 AM
gregsdart Offline
gregsdart  Offline
Originally Posted by Twostick
Will a spacer work?
Kevin
bingo!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
