Advice wanted for removing grease from intake manifold #3244370
07/14/24 10:05 AM
07/14/24 10:05 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Any product recommendations for removing grease from a stock cast iron ntake manifold?
The manifold has been removed from the engine assembly, but no access to a parts washer/hot tank.
Not sure if brake parts clean would be a good product.
The plan is to repaint the intake.
Re: Advice wanted for removing grease from intake manifold [Re: vinnyd76] #3244373
07/14/24 10:29 AM
07/14/24 10:29 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Mineral spirits and a brush followed by Dawn dishwasher soap and hot water.
Re: Advice wanted for removing grease from intake manifold [Re: 6PakBee] #3244386
07/14/24 11:34 AM
07/14/24 11:34 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Regular Easy Off oven cleaner. Just be careful of any over spray. Very caustic and tough on skin/paint etc.
Carl Kessel
Re: Advice wanted for removing grease from intake manifold [Re: CKessel] #3244588
07/15/24 05:46 AM
07/15/24 05:46 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Yes yes and yes! I cannot imagine scrubingb with a brush and getting it flung into my eye. Its bad enough on the skin or your arm or hand. Use caution.
Keep old mopars alive.
Re: Advice wanted for removing grease from intake manifold [Re: CKessel] #3244643
07/15/24 11:31 AM
07/15/24 11:31 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Works great on undercoating too. Scrapes off real easy.
Re: Advice wanted for removing grease from intake manifold [Re: 2boltmain] #3244645
07/15/24 11:35 AM
07/15/24 11:35 AM
5thAve Offline
5thAve  Offline
Brake cleaner or engine cleaner, varsol etc and a rag. Heat off whats left with a torch ozbbq beer
Re: Advice wanted for removing grease from intake manifold [Re: vinnyd76] #3246864
07/23/24 07:44 PM
07/23/24 07:44 PM
Richmond Ohio
alexdodge2 Offline
alexdodge2  Offline
Richmond Ohio
Electra Motive in spray can
Re: Advice wanted for removing grease from intake manifold [Re: alexdodge2] #3246866
07/23/24 07:52 PM
07/23/24 07:52 PM
Mass
charge70 Offline
charge70  Offline
Mass
Get a can of Gunk degreaser and hit the local diy car wash
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Advice wanted for removing grease from intake manifold [Re: charge70] #3246940
07/24/24 07:02 AM
07/24/24 07:02 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
A degreaser and a pressure washer. up
Re: Advice wanted for removing grease from intake manifold [Re: Moparite] #3246980
07/24/24 11:09 AM
07/24/24 11:09 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Wire brush it off as best you can and use dish soap and hot water to get the rest off. Could also use any solvent as well
Car wash to clean parts in this area is no longer allowed where I'm at. Nearest car wash has security cameras in each bay + signs that say no washing of engines or engine parts allowed. The water temp and water pressure they have those set on is not like a Hotsy sprayer so I doubt they would work for heavy grease removal.
