has anyone used Mancini / HS rockers on trick flo SB heads #3246918
07/23/24 11:06 PM
07/23/24 11:06 PM
BigFish69 Offline OP
Mancini rockers made by HS MRE67001-15 has anyone used these on trick flo 190 SB heads?
Re: has anyone used Mancini / HS rockers on trick flo SB heads [Re: BigFish69] #3246928
07/24/24 12:10 AM
07/24/24 12:10 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Got a local buddy, long time racer, who has those rockers on a 264/268@50 Hughes solid 600+ lift who is using the Trick flows.
He is very happy with that setup, liked how everything lined up. Has street driven and raced the car. Been on probably 3 years now.
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: has anyone used Mancini / HS rockers on trick flo SB heads [Re: BigFish69] #3246942
07/24/24 07:13 AM
07/24/24 07:13 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My dad has a set of the 1.6 rockers on his 360 with Trick Flow heads. He has a solid flat tappet with just under .600 lift, hasn't had any issues with them.
Re: has anyone used Mancini / HS rockers on trick flo SB heads [Re: DusterKid] #3246977
07/24/24 10:58 AM
07/24/24 10:58 AM
Sounds good thanks for the reply
Tom
