Alternator failure, 3 times this season, Ideas?
#3246780
07/23/24 12:12 PM
07/23/24 12:12 PM
Posts: 10,008 MI, usa
dvw
MI, usa
Running a Power Master GM 25SI alternator. 16 volt with the XS adjustable regulator. Works fine 2-3 outings then quits. This weekend was the 3rd one. The block is grounded to the cage. The alternator case is grounded to the cage not only bolted but with a cable. The battery is grounded to the cage. Voltage drop between the negative battery terminal and the alternator is less than 1 volt under load. The posistive cable is sized 02. It has one connection at a fire wall bulkhead shared by the starter, alternator, and main feed to all the other components. The only other junction is the main cut off switch. The car cranks very easily at 15-1 comppresion, ignition on, with 34 total. It seems like the failure occurs when starting 1st thing in the morning. Battery is alway charged with the cars circuits disconnected at the main switch. Pulley size is exactly what they suggest. Never had an issue with the previous alternator. It just didn't have enough capacity. They suggest a ground from the battery. I don't buy that. There isn't a production car in the world that has a negative cable from th ealternator to the battery. Could there be a spike during crank? don't know. And if there is why does it take a month unttil it fails. I'm at a loos. Doug
Re: Alternator failure, 3 times this season, Ideas?
[Re: dvw]
#3246781
07/23/24 12:17 PM
07/23/24 12:17 PM
Posts: 19,575 Las Vegas
Al_Alguire
Las Vegas
We have had ZERO luck using anyones adjustable 16V regulated alternators. Finally got HOP to admit they shoudl not even sell them but some guys with lithiums need/want them.
[Re: dvw]
#3246809
07/23/24 02:17 PM
07/23/24 02:17 PM
Posts: 207 Connellsville
71Demon528
Connellsville
Doug, the only thing I can think to suggest, whether I am right, wrong, and someone agrees or disagrees, I would connect the charge back wire directly to the positive, NOT A SHARED power post that runs back to the battery. My understanding is that hooking up the alternator to a shared power post, the alternator is backfeeding the battery, after it is giving power to all your accessories first. I believe this can cause a potential spike. (Again, just my understanding) When hooking up directly to the battery post, the alternator is purely feeding the battery, and the battery is feeding your accessories. Why did your other alternators have no issue? I wish I could explain that. But I would say with the new alternator having issues, if it were my car, that is where I would PERSONALLY start. It may not make any difference, but just my opinion. I even did this with my dads car with a 75amp XS Volt alternator and it made a big difference when I simply hooked it directly to the battery.
I run an XS Volt adjustable regulator alternator from powermaster, part number 8148. Turned up to 18.5 volts, 65 amp charge at idle, 150 amp at full throttle. I originally had it hooked up to my common power post, and it would not function 100% the way I felt it should work. Never failed, but there was a time or two where it stopped charging. I simply ran a wire directly from the alternator to the battery, and never had an issue since. It’s been on my car since 2019. It does such a good job I never have to charge my battery on race day.
Again, right, wrong, or indifferent, agree, disagree, I think that is where I would start.
RJ
[Re: dvw]
#3246817
07/23/24 02:33 PM
07/23/24 02:33 PM
Posts: 4,754 On the parachute mount
n20mstr
Running a Power Master GM 25SI alternator. 16 volt with the XS adjustable regulator. Works fine 2-3 outings then quits. This weekend was the 3rd one. The block is grounded to the cage. The alternator case is grounded to the cage not only bolted but with a cable. The battery is grounded to the cage. Voltage drop between the negative battery terminal and the alternator is less than 1 volt under load. The posistive cable is sized 02. It has one connection at a fire wall bulkhead shared by the starter, alternator, and main feed to all the other components. The only other junction is the main cut off switch. The car cranks very easily at 15-1 comppresion, ignition on, with 34 total. It seems like the failure occurs when starting 1st thing in the morning. Battery is alway charged with the cars circuits disconnected at the main switch. Pulley size is exactly what they suggest. Never had an issue with the previous alternator. It just didn't have enough capacity. They suggest a ground from the battery. I don't buy that. There isn't a production car in the world that has a negative cable from th ealternator to the battery. Could there be a spike during crank? don't know. And if there is why does it take a month unttil it fails. I'm at a loos. Doug forget grounds to the cage. Run a ground direct from the battery to the block. Prodcution cars dont have 15-1 compression LOL
....BAD A$$ STREET CAR.....
[Re: dvw]
#3246832
07/23/24 04:09 PM
07/23/24 04:09 PM
Al_Alguire
Las Vegas
My question would be WHY even use an adjustable regulator. The only reason we tried was for lithium batteries. I no longer use an adjustable regulator and not an issue. Both card work fine unregulated with a 16 volt alternator. As stated earlier we had ZERO luck with Powermaster or House of Payne alternators with adjustable regulators.
[Re: Leigh]
#3246892
07/23/24 09:29 PM
07/23/24 09:29 PM
Posts: 10,963 North Dakota
6PakBee
North Dakota
What is failing on the alternators? Stator? Rotor? Diodes? Brushes? A little postmortem autopsy may be in order here.
[Re: 6PakBee]
#3246897
07/23/24 09:39 PM
07/23/24 09:39 PM
dvw
MI, usa
What is failing on the alternators? Stator? Rotor? Diodes? Brushes? A little postmortem autopsy may be in order here. To be honest they went back to Summit. The windings, rotor, and diodes all looked good. Nothing burned up. Though I did not test them. I suspect the regulator. Doug
[Re: dvw]
#3246967
07/24/24 10:18 AM
07/24/24 10:18 AM
6PakBee
North Dakota
What is failing on the alternators? Stator? Rotor? Diodes? Brushes? A little postmortem autopsy may be in order here. To be honest they went back to Summit. The windings, rotor, and diodes all looked good. Nothing burned up. Though I did not test them. I suspect the regulator. Doug So you really were having regulator failures, not alternator failures? Not trying to be a d$ck here but like anything, if you don't know what the problem is, it's hard to find a solution. Just a thought, I've never worked around a 16 volt system. What is the desired charging voltage? There are regulators available for Motorola alternators with about a 15.5 volt setpoint. I would think you could also use a simple voltage divider to "fool" a conventional voltage regulator into controlling at a higher voltage.
[Re: 6PakBee]
#3246971
07/24/24 10:32 AM
07/24/24 10:32 AM
Posts: 8,091 Tulsa OK
Bad340fish
Tulsa OK
II don't know if you can easily switch styles but I have been running a GM CS130 from Orielly's for years. I have replaced it once in 12 years and it turns out it wasn't really the alternator it was my continuous duty relay starting to fail.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3246997
07/24/24 12:37 PM
07/24/24 12:37 PM
Al_Alguire
Las Vegas
Took a number of retured failed alternators and phone calls before HOP admitted the regulators were and issue. I have been running 16V alternators for years. On MSD 7AL boxes, Digital 7's and Grids and never had an issue there. The only reason we tried the adjustable was when running a lithium battery as they will not tolerate even 18 volts
