Where to get -New clutch for 67 Barracuda 273 4 speed #324643
05/21/09 11:27 AM
05/21/09 11:27 AM
mikemotorhead Offline OP
super street
super street
Car still has original clutch. I would like to put in something easy to drive in traffic.
Thanks Mike
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: mikemotorhead] #324644
05/21/09 12:46 PM
05/21/09 12:46 PM
I picked up a Zoom clutch from Jegs and I like it. Mine's a 318 4 speed.
770-MU1647-1
http://www.jegs.com/i/Zoom+Clutches/770/MU1647-1/10002/-1
Re: Where to get -New clutch for 67 Barracuda 273 4 speed #324645
05/21/09 12:50 PM
05/21/09 12:50 PM
super street
super street
Thanks 64 I checked out the link but did not see a 67 273 listed!
Mike
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: mikemotorhead] #324646
05/21/09 12:55 PM
05/21/09 12:55 PM
Should be a 10 1/2" 23 spline like mine. Check Rockauto for the size. Mine's a 70 318 in mine but it had the 10 1/2".
http://www.rockauto.com/catalog/raframecatalog.php
1967 PLYMOUTH BARRACUDA 4.5L 273cid V8 : Clutch : Clutch Kit Price Core Total
RHINO PAC Part # 05029A
Base; Diaphragm Option Kit; Disc Spec: 10-1/2" OD X 1" ID X 23T, Flywheel Spec: Flat
$138.79 $0.00 $138.79
$139.79 $0.00 $139.79
Base; Disc Spec: 10-1/2" OD X 1" ID X 23T, Flywheel Spec: Flat; Lever Style; Standard Kit
$142.79 $0.00 $142.79
SACHS Part # K167503
10 1/2 Inch Clutch; OD: 10 1/2; Size ID: 1; TEETH: 23T
* Non-stock item--shipping delayed up to 2 business days
$130.79 $0.00 $130.79
Re: Where to get -New clutch for 67 Barracuda 273 4 speed #324647
05/21/09 12:59 PM
05/21/09 12:59 PM
The one I posted will fit. This came up as the HP(expensive one) one for your car, same size.
http://www.jegs.com/i/Zoom+Clutches/770/HP1647-1/10002/-1
http://cgi.ebay.com/ebaymotors/Zoom-HP16...4291210009r2995
Re: Where to get -New clutch for 67 Barracuda 273 4 speed #324648
05/21/09 01:23 PM
05/21/09 01:23 PM
super street
super street
Thanks 64 I do have the HP solid lifter motor. Should I get the HP one?
Mike
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: mikemotorhead] #324649
05/21/09 01:33 PM
05/21/09 01:33 PM
It's double the price and I don't know what kind of feel it will have to it. The last zoom I ran was over 30 years ago and it was a @*&#@ to push in. I only know the one I got for my 64 has a nice feel and they say it has more grip. Some on here may have more experience if you want something stronger.
Re: Where to get -New clutch for 67 Barracuda 273 4 speed #324650
05/21/09 01:42 PM
05/21/09 01:42 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had a Zoom in my 65 440 years ago.Lasted like 6 months.I like my Center Force.Expensive but light pressure and they last and grab.Just remove the over center spring.Rocky
Chrysler Firepower
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: mikemotorhead] #324651
05/21/09 06:14 PM
05/21/09 06:14 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Thanks Mike
I'm not 100% sure but I think the original clutch would be either a 9.25 or 10" so a 10.5" will not fit that flywheel. I may be wrong but it might be worth checking before ordering.
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: 446acuda] #324652
05/21/09 06:30 PM
05/21/09 06:30 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Easy way to tell is remove lower cover. 5-7/8" between pressure plate bolt holes shown here is for 10.5" clutch and approximately 5-1/4 between holes is a 9-1/4 or 10". Even easier is that 10.5" uses 3/8" pressure plate bolts (9/16" wrench) and 9-1/4 and 10 use 1/2" or smaller wrench.
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: 446acuda] #324653
05/21/09 06:46 PM
05/21/09 06:46 PM
My 65 Barracuda which originally was a hi-po 273 4-speed came from the factory with a 9.5" clutch. Not sure about 67's, check before ordering a replacement.
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: 446acuda] #324654
05/23/09 10:52 AM
05/23/09 10:52 AM
Penna
70satelliteguy Offline
Penna
446acuda,I have 1/2 in. bolts and the distance between the pressure plate bolts is approx. 5-1/4 in. How do I tell if I should order a 9-1/4 or a 10.0 in. clutch?
Thanks Mike ( mikemotorhead at home computer)
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: 70satelliteguy] #324655
05/23/09 12:23 PM
05/23/09 12:23 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
either one, see the PM I sent you.
Re: Where to get -New clutch for 67 Barracuda 273 4 speed [Re: 446acuda] #324656
05/25/09 02:07 AM
05/25/09 02:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
any 273 ive ever seen was 9 1/2,may not be enough room in a factory bell housing for a 10 inch clutch,,any good auto parts store can get you what you need,,or search rock auto for cross refrenceing, center force might make one im sure mc loed makes one
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
