Steering column coupler press pin #3246375
07/21/24 08:51 PM
07/21/24 08:51 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Been trying to install my steering column coupler press pin. Is there some particular way it's supposed to go in or to install it? I've been beating on it with a hammer and it's only gone in far enough to where it doesn't fall out. I can't get it to go in all the way through the coupler and I'm afraid the power steering box might get effed up from all the pounding.
Re: Steering column coupler press pin [Re: 6PAX] #3246377
07/21/24 08:55 PM
07/21/24 08:55 PM
A727Tflite Offline
A727Tflite  Offline
You have the coupler on all the way and aligned properly?
You should see a straight “hole” when you look in to that bore. Find a drill bit a tad smaller than the pin and it should slide in.
Re: Steering column coupler press pin [Re: A727Tflite] #3246382
07/21/24 09:04 PM
07/21/24 09:04 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Yes, I can see clear through the round hole in the coupler. I also should mention, the steering box, coupler and pin are the originals to the car.
Re: Steering column coupler press pin [Re: 6PAX] #3246395
07/21/24 09:45 PM
07/21/24 09:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I assume you are talking about the roll / spring pin and NOT the hardened solid pin inside the box
IF so and its not going in with just some moderate effort. its not lined up right
Re: Steering column coupler press pin [Re: gtx6970] #3246396
07/21/24 09:51 PM
07/21/24 09:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
One end of the pin has a tapered edge. It helps if you put that end in first
Re: Steering column coupler press pin [Re: 6PAX] #3246415
07/21/24 10:47 PM
07/21/24 10:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try squeezing it in with a C clamp.
