Re: 46re questions
[Re: volaredon]
#3246537
07/22/24 12:28 PM
07/22/24 12:28 PM
Posts: 26,384 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With the front servo you have, lever free play should be 5/16"-3/8". Hard to measure the rear free play, so 2 turns out from 72 in. lbs. is good.
Re: 46re questions
[Re: volaredon]
#3246802
07/23/24 01:41 PM
07/23/24 01:41 PM
John_Kunkel
Rio Linda, CA
The stock "controlled load" front servo piston rod remains extended a little after the 2-3 shift so it needs to be adjusted looser. Not so with the aftermarket billet servo pistons.
