Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245305
07/17/24 04:04 PM
07/17/24 04:04 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
with flat paper / fiber gaskets. I'll use KW coppercoat or brushable Permatex ( the purple stuff )
Enjoy life today, It has an expiration date
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245351
07/17/24 07:31 PM
07/17/24 07:31 PM
Torq37 Offline
Torq37  Offline
Originally Posted by A990
Originally Posted by DaveRS23
...I use Permatex's version of Hylomar. twocents
Whoa, hold on
Permatex dropped that license years ago. Did they restart again?
I had to order a tube from England, but it is worth every penny.
Permatex Permashield in an orange tube. Has been available on Amazon for at least a couple years that I know of.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245367
07/17/24 08:11 PM
07/17/24 08:11 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Whoa, hold on
Here ya go:
www.amazon.com/Permatex-85420-Perma...LBVA3aOuaLzIb7pIzUoVlT2CsQvu8fQct-MBURO-
www.amazon.com/Permatex-PermaShield...LBVA3aOuaLzIb7pIzUoVlT2CsQvu8fQct-MBURO-
Same stuff just different source and price.
Master, again and still
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245372
07/17/24 08:55 PM
07/17/24 08:55 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Thanks.
Thats my mostly used sealant anymore.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245385
07/17/24 09:44 PM
07/17/24 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
no offense but they'd probably like to sell you a special sealant for everything 🙄🤣 beer
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245411
07/17/24 11:40 PM
07/17/24 11:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
So in my travels to the auto parts stores I noticed that some of the application specific stuff Permatex sells comes in smaller sized tubes. That means you get enough for the task at hand, and don't get stuck with a 3/4 full tube of leftovers after a repair project that just sits on the shelf and dries up. When looked at it that way it's less money wasted unless your replacing multiple water pumps every month as a tech. Then the bigger tubes are what you'd want to have around.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Neil] #3245485
07/18/24 10:50 AM
07/18/24 10:50 AM
moparx Offline
moparx  Offline
i have heard that storing tubes of sealant and glues in a refrigerator keeps them from going bad.
any truth to that ?
if so, i would be worried smells from them would permeate food items. would keeping that kind of stuff in a tupperware type container prevent that from happening ?
beer
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245487
07/18/24 10:56 AM
07/18/24 10:56 AM
an8sec70cuda Offline
Originally Posted by Stanton
Should sealant be used on the blue Felpro w/p gasket - big block pump to pump housing ??
I always use a light coat of ultra grey silicone on them.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245523
07/18/24 02:47 PM
07/18/24 02:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A lot of those sealants are more readily available because of the ISO (i.e., 9001 etc.,) and MIL specs standards. At work we had to use Loctite Gasket Eliminator and make sure we used the correct one for the correct application of either LGE 515, 518 or 5188 and several other types in case of an ISO audit. Just saying why there are so many variations now. They call it "International Grey" sealant for a reason. wink
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245550
07/18/24 05:58 PM
07/18/24 05:58 PM
I use that on thermostat housing with the stock composition gaskets, works good, last a long time wrench up scope twocents
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245681
07/19/24 09:37 AM
07/19/24 09:37 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I'm leaning towards the Permatex red stuff in the spray can.
Haven't seen that stuff since I last built motors at my uncle's machine shop. I can smell it now. What I still use from those days is Permatex Aviation Form A Gasket on paper gaskets. I just remember that red stuff getting on everything after a while. The Aviation stuff brushes on, and it's impossible to use too much. I can't stand silicone, and I've seen many motors with chunks of that [censored] plugging passages. I remember pulling a crank out, and there was a chunk of that crap right in the main bearing oil hole.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: 375inStroke] #3245683
07/19/24 09:42 AM
07/19/24 09:42 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The red Permatex stuff in both spray and brush is still on the shelves.
I really like that stuff for almost all apps.
Spray or brush it on, let it tack-up for a minute.
Excellent for machined surfaces, gas, oil or water.
Joe
Re: Sealant on blue Felpro waterpump gasket ?? [Re: jlatessa] #3245721
07/19/24 12:55 PM
07/19/24 12:55 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Indian Head Shellac?
Re: Sealant on blue Felpro waterpump gasket ?? [Re: moparx] #3245812
07/19/24 08:29 PM
07/19/24 08:29 PM
IMGTX Offline
IMGTX  Offline
any truth to that ?
beer
Cold will slow most chemical & biological reactions so it should help but exposure to air/moisture is the real kicker on these sealants.
I just keep the tubes capped and if the end hardens stick a screwdriver through the end to get the soft stuff. When that stops working I find a soft spot and poke though the side.
Pretty much what every body i know does..
I toss out less than an1/8th of a tube a year and I don't look back.
I would loose mine in the fridge.
