68 road runner fan shroud #3245334
07/17/24 06:30 PM
07/17/24 06:30 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
I am curious on what fan shroud my 68 road runner should have. It currently doesn't have one, and the radiator has no place to mount one. Would it be the 2 piece metal one, or a one piece plastic? 22" radiator, no A/C. Thanks!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 68 road runner fan shroud [Re: Prodart440] #3245386
07/17/24 09:45 PM
07/17/24 09:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The shroud on my '68 RR (22" radiator) is a 2-piece metal deal.
Upper & lower halves, mounted using brackets that attach to the shroud sides and the sides of the radiator.
Re: 68 road runner fan shroud [Re: topside] #3245498
07/18/24 12:41 PM
07/18/24 12:41 PM
Avondale AZ
Avondale AZ
Thanks! That's what I thought. Do you have pictures of the brackets you could send me? I will have to make them. I have the 2 pieces of the shroud already.
Aaron
68 Coronet 440
Re: 68 road runner fan shroud [Re: Prodart440] #3245511
07/18/24 01:24 PM
07/18/24 01:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I can take some later on - Classic Industries has a repro setup, if that helps.
Re: 68 road runner fan shroud [Re: topside] #3245515
07/18/24 02:05 PM
07/18/24 02:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Left & Right brackets - note slight width offset.
Re: 68 road runner fan shroud [Re: topside] #3245528
07/18/24 03:44 PM
07/18/24 03:44 PM
Avondale AZ
Avondale AZ
Thanks for the pictures! I got this shroud off a wrecked 69 GTX, with a 68 front clip. I had assumed that it was a 68 B body shroud. Now, after seeing your pictures I know it's not. Any idea what it is from?
Aaron
68 Coronet 440
Re: 68 road runner fan shroud [Re: Prodart440] #3245599
07/18/24 07:39 PM
07/18/24 07:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Nope - looks a bit similar, but appears to bolt on differently.
It might work with mods to use side brackets, if accuracy isn't a concern.
What I remember of my Early B shrouds is that they were like the '68 in shape & mounting.
The 22" radiator in my '69 RR - very original, unmolested, super-low mile car - looks like my '68 car, same shroud mounting holes, but has no shroud.
I think the plastic 22" shrouds debuted maybe '70 model year ?
My 26" radiator '68 RRs used plastic shrouds, though.
Re: 68 road runner fan shroud [Re: topside] #3245715
07/19/24 12:28 PM
07/19/24 12:28 PM
moparx Offline
moparx  Offline
if the shroud pictured is plastic, it almost looks like a cut down mid to late 70's C-body shroud. maybe ? shruggy
beer
Re: 68 road runner fan shroud [Re: moparx] #3245738
07/19/24 01:56 PM
07/19/24 01:56 PM
Avondale AZ
Avondale AZ
The shroud is steel. I think it's from a C-body.
Aaron
68 Coronet 440
