Re: Sealant on blue Felpro waterpump gasket ??
[Re: Stanton]
#3245017
07/16/24 01:30 PM
07/16/24 01:30 PM
Posts: 43,637 Bend,OR USA
Cab_Burge
[Re: DaveRS23]
#3245112
07/16/24 10:07 PM
07/16/24 10:07 PM
Posts: 9,014 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
"This is what Permatex recommends:
www.permatex.com/products/gasketing...ermostat-rtv-silicone-gasket-maker-5-oz/"
I didn't read "big block Mopar" anywhere there.
Anyhow, I don't want to "make" a gasket, I just want to coat/seal the gasket.
Personally I don't think RTV and a cardboard gasket are meant to go hand in hand. I'm leaning towards the Permatex red stuff in the spray can. Wouldn't have even asked the question if I'd had the thing in my hand at the time.
[Re: Neil]
#3245127
07/17/24 12:42 AM
07/17/24 12:42 AM
Posts: 12,250 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Paper gaskets go on dry, with a thin smear around any areas adjacent to water that may show corrosion or pitting.
[Re: DaveRS23]
#3245178
07/17/24 08:51 AM
07/17/24 08:51 AM
Posts: 5,446 Indiana
YO7_A66
Indiana
I use the above Permatex Blue on everything that touches coolant (intake, thermostat housing, water pump/housing, hoses, etc.). It's kind of hard to find it anymore in stores in the larger tube, so I usually buy the smaller tubes and have them on hand.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#3245194
07/17/24 09:43 AM
07/17/24 09:43 AM
Posts: 12,743 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Shouldn't WHAT fluid the gasket and sealant are sealing against be considered? Personally, I never put any gasket on dry anymore. If nothing else, I use Permatex's version of Hylomar. But never dry. If you have good luck with gaskets sealing dry, then by all means keep doing it. But I got broke of that a long time ago. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Master, again and still
[Re: DaveRS23]
#3245295
07/17/24 03:14 PM
07/17/24 03:14 PM
Posts: 2,778 541 slobovia
A990
541 slobovia
...I use Permatex's version of Hylomar. Whoa, hold on Permatex dropped that license years ago. Did they restart again? I had to order a tube from England, but it is worth every penny.
