Re: Sealant on blue Felpro waterpump gasket ??
[Re: A990]
#3245351
07/17/24 07:31 PM
07/17/24 07:31 PM
Torq37
...I use Permatex's version of Hylomar. Whoa, hold on Permatex dropped that license years ago. Did they restart again? I had to order a tube from England, but it is worth every penny. Permatex Permashield in an orange tube. Has been available on Amazon for at least a couple years that I know of.
[Re: Neil]
#3245485
07/18/24 10:50 AM
07/18/24 10:50 AM
Posts: 20,212 north of coder
moparx
i have heard that storing tubes of sealant and glues in a refrigerator keeps them from going bad. any truth to that ? if so, i would be worried smells from them would permeate food items. would keeping that kind of stuff in a tupperware type container prevent that from happening ?
[Re: Stanton]
#3245487
07/18/24 10:56 AM
07/18/24 10:56 AM
Posts: 13,489 Marion, South Carolina [><]
an8sec70cuda
Should sealant be used on the blue Felpro w/p gasket - big block pump to pump housing ?? I always use a light coat of ultra grey silicone on them.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Stanton]
#3245681
07/19/24 09:37 AM
07/19/24 09:37 AM
Posts: 1,549 Seattle, WA
375inStroke
Special needs person
Seattle, WA
I'm leaning towards the Permatex red stuff in the spray can.
Haven't seen that stuff since I last built motors at my uncle's machine shop. I can smell it now. What I still use from those days is Permatex Aviation Form A Gasket on paper gaskets. I just remember that red stuff getting on everything after a while. The Aviation stuff brushes on, and it's impossible to use too much. I can't stand silicone, and I've seen many motors with chunks of that [censored] plugging passages. I remember pulling a crank out, and there was a chunk of that crap right in the main bearing oil hole.
[Re: moparx]
#3245812
07/19/24 08:29 PM
07/19/24 08:29 PM
Posts: 12,303 Looking for a way out of Middl...
IMGTX
i have heard that storing tubes of sealant and glues in a refrigerator keeps them from going bad. any truth to that ? if so, i would be worried smells from them would permeate food items. would keeping that kind of stuff in a tupperware type container prevent that from happening ? Cold will slow most chemical & biological reactions so it should help but exposure to air/moisture is the real kicker on these sealants. I just keep the tubes capped and if the end hardens stick a screwdriver through the end to get the soft stuff. When that stops working I find a soft spot and poke though the side. Pretty much what every body i know does.. I toss out less than an1/8th of a tube a year and I don't look back. I would loose mine in the fridge.
