Re: 69 A12 CAR metering valve and hold off valve part number ?
[Re: THESHAKERPROJECT]
#3245025
07/16/24 02:08 PM
07/16/24 02:08 PM
Posts: 26,384 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It helps if you use the correct factory terminology. To some, the metering valve and the "hold off valve" (non-factory term) are the same thing.
[Re: dragon slayer]
#3245668
07/19/24 08:19 AM
07/19/24 08:19 AM
Posts: 75,265 A gulag near you.
JohnRR
A gulag near you.
I thought A12 were drum cars. Do you have Power Disc brakes??
I think you are talking about Distribution block. The Rear Proportioning valve was for disc brake only. The metering valve or hold off for the front disc brakes was not used until 1970 B body KH system. Correct , 69 A12 was either manual 11" drums or 11" power drums , no discs , no metering valve in the rear line that is a disc brake item only. The only valve in the brake system is a distribution block that contains the brake failure warning light switch. The picture posted above is for disc brake applications 1970 and up.
Mainstream Media is the new Pravda
[Re: John_Kunkel]
#3245690
07/19/24 10:12 AM
07/19/24 10:12 AM
Posts: 1,171 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
So yes its a drum brake car so I may need just the distribution block......ANYBODY have the PART number ???
#3245698
07/19/24 11:16 AM
07/19/24 11:16 AM
Posts: 1,296 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Mike - Does this mean the A12 car has been moved from Jason's shop to yours?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
