More test results
#3244457
07/14/24 04:20 PM
07/14/24 04:20 PM
Posts: 4,736 On the parachute mount
n20mstr
Recently switched from plate to a direct port . I went Friday to Lebanon Valley for a radial prep test and tune . I upped the jet a little and it worked out to about 300pph more ( roughly 80 hp ) Wow what a difference because it was a lot more violent . After playing with rear shocks and timing got it to go down . Wheelie control was on for .6 in the 60’ but it still went 1.16 . Air was horrible with 113 water grains .
....BAD A$$ STREET CAR.....
Re: More test results
[Re: n20mstr]
#3244491
07/14/24 06:15 PM
07/14/24 06:15 PM
Posts: 8,220 Plymouth, MI
Blusmbl
Plymouth, MI
That's a killer shot with the candles lit!!
I'd heard from other nitrous friends (that haven't messed with nitrous cars in 20 years, lol) that plate kits typically hit harder than foggers but the foggers are better for cylinder to cylinder distribution. Assuming that's false? Can you go all in at launch and just control it with timing or do you have to ramp the nitrous in too?
[Re: Blusmbl]
#3244500
07/14/24 06:59 PM
07/14/24 06:59 PM
n20mstr
I'd heard from other nitrous friends (that haven't messed with nitrous cars in 20 years, lol) that plate kits typically hit harder than foggers but the foggers are better for cylinder to cylinder distribution. Assuming that's false? Can you go all in at launch and just control it with timing or do you have to ramp the nitrous in too? Yes typically a plate hits harder , but I upped the jet 80 or more hp Yes the nitrous is ramped in , pretty lazy but all in by 1.0 seconds Now it’s just a matter of getting more aggressive with the ramp and timing . Right now there still no heat on the straps Just have to play with the wheelie control and move some weight to keep it off the wheelie control.
[Re: dvw]
#3244544
07/14/24 11:34 PM
07/14/24 11:34 PM
Posts: 11,782 Portage,michigan
B3422W5
Portage,michigan
Cool deal Impressive how you pick away at stuff and continue to move forward.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: GY3]
#3244613
07/15/24 09:42 AM
07/15/24 09:42 AM
Posts: 13,480 Marion, South Carolina [><]
an8sec70cuda
Awesome pic! It's flying!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3244667
07/15/24 12:36 PM
07/15/24 12:36 PM
Posts: 1,296 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I look forward to seeing it run in person ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3245343
07/17/24 07:11 PM
07/17/24 07:11 PM
Posts: 5,020 new jersey usa
11secdart
new jersey usa
Looking good Tony !!! I saw a video of one of your runs at LV on Facebook
[Re: hemi-itis]
#3246688
07/23/24 01:26 AM
07/23/24 01:26 AM
Posts: 6,402 Heaven
EvilB1Dart
Heaven
You’ll definitely be in the mix Tony once you get more laps and aggressive. No heat on the straps yet LOL. Are you using a stand alone controller or are you progressing through your Holley EFI setup? I cannot remember.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3246762
07/23/24 11:17 AM
07/23/24 11:17 AM
n20mstr
You’ll definitely be in the mix Tony once you get more laps and aggressive. No heat on the straps yet LOL. Are you using a stand alone controller or are you progressing through your Holley EFI setup? I cannot remember. Using the Holley EFI nitrous progressive, and there is a lot of room there ......because it is not agressive at all yet ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) As usual have some testing to do between front shocks , weight and timing/progressive settings to keep it out of wheelie control, Once its not hitting wheelie control it should pick up some good numbers in the 60 and 330
[Re: n20mstr]
#3247236
07/25/24 01:01 PM
07/25/24 01:01 PM
Posts: 19,522 Las Vegas
Al_Alguire
Las Vegas
Progress is good and sounds like you have plenty of room left to go..
