What length bolts for dodge connection steering brace on 4x4 #3244181
07/13/24 04:58 PM
07/13/24 04:58 PM
Bucksport,Maine
Ryan'sW250 Offline OP
Bucksport,Maine
Just ordered the dodge connection steering box brace for my 1989 Dodge Ram W250 4x4 with a 6" lift on 37's
Also just received in the mail my brand new Borgeson upgraded steering box & steering shaft.
So on the website it says I need these bolts:
4 - 7/16"- 14 x 1 3/4" Grade "8" bolts
6 - 7/16" Grade "8" Lock Washers
6 - 7/16" Grade "8" Flat Washers
2 - 7/16" Grade "8" Nuts
Now I know I will need longer bolts because mine is 4wd and the info on the website is for the 2wd. And the 4wd come with a side plate.
So do you think 2 1/4" should be long enough?
Also what length bolts to go up into the cross member under the radiator? I'm pretty sure I don't have to do any drilling because there's already a couple holes and a slot there.
Re: What length bolts for dodge connection steering brace on 4x4 [Re: Ryan'sW250] #3244345
07/14/24 08:32 AM
07/14/24 08:32 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If this is a copy of the factory bracket, the holes are there. Also the 3 bolts for the box mount are usually long enough. You'll just need a couple for the crosmember holes.
Angry white pureblood male
Re: What length bolts for dodge connection steering brace on 4x4 [Re: ruderunner] #3244519
07/14/24 08:57 PM
07/14/24 08:57 PM
Bucksport,Maine
Bucksport,Maine
I just want to know what length bolts will work? The factory bolts will be too short once I add the brace. Probably not by much though. The description on the dodge connection site says 1 3/4 for the 2wd model. I'm wondering if 2" would be enough or 2 1/4"
Re: What length bolts for dodge connection steering brace on 4x4 [Re: Ryan'sW250] #3244633
07/15/24 11:06 AM
07/15/24 11:06 AM
moparx Offline
moparx  Offline
for all the more the bolts would cost, and how few are needed, you could just grab several lengths to insure you had the correct length, then return the unused ones.
or keep 'em like i do, and wonder in the future why you have so many bolts you will never use in 6 lifetimes....... biggrin
beer
Re: What length bolts for dodge connection steering brace on 4x4 [Re: moparx] #3244782
07/15/24 05:47 PM
07/15/24 05:47 PM
Bucksport,Maine
Bucksport,Maine
That is a good idea
Re: What length bolts for dodge connection steering brace on 4x4 [Re: Ryan'sW250] #3251475
08/14/24 07:30 PM
08/14/24 07:30 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
If you do not mind me asking - what length bolt did you end up needing? I would like to add the info to our website
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: What length bolts for dodge connection steering brace on 4x4 [Re: LilRed7879] #3251479
08/14/24 07:46 PM
08/14/24 07:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
In this area, you but grade 8 bolts in 1/2" lengths once you get past 2" long. So you buy a 2" or a 2 1/2" long bolt. I suspect the 2" long bolt will be plenty long enough. As long as the full width of the nut is on the bolt threads when the bolt is tight, that is enough.
