Best way to revive used nuts and bolts #3243811
07/11/24 11:37 PM
07/11/24 11:37 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I’ve heard soaking them in white vinegar over night, then taking a wire wheel to finish them off. Does anyone have a better way that works?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: BloFish] #3243815
07/12/24 12:21 AM
07/12/24 12:21 AM
Morgan Hill, CA
ackpht Offline
ackpht  Offline
Morgan Hill, CA
I used to have a "Tumble Vibe" which was a bowl filled with abrasive material and shaken by an electric motor. You put small parts in and let it run overnight. For larger parts I just use a blast cabinet.
Re: Best way to revive used nuts and bolts [Re: ackpht] #3243816
07/12/24 12:37 AM
07/12/24 12:37 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Soak in Evaporust.
Re: Best way to revive used nuts and bolts [Re: BloFish] #3243824
07/12/24 02:33 AM
07/12/24 02:33 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
I just put them in the blaster with glass bead media, i can do a ground of fender and door bolts in a few minutes. cleans everything up great without taking good metal away.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Best way to revive used nuts and bolts [Re: BloFish] #3243848
07/12/24 08:50 AM
07/12/24 08:50 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Evaporust is quicker than vinegar and can work better on more heavily rusted pieces. But vinegar does work. I glass bead some and wire wheel some others. Just depends on the item, it's condition, and what it needs to look like in the end. Getting all the oil and grease off the piece before doing anything else is important.
Then there's the challenge of duplicating the original finish and getting it to live.
Master, again and still
Re: Best way to revive used nuts and bolts [Re: Neil] #3243854
07/12/24 09:11 AM
07/12/24 09:11 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted by Neil
Soak in Evaporust.
Same here , I have gallons of the stuff , works wonders on original hardware to revive it , as long as they are too crusty.
Mainstream Media is the new Pravda
Re: Best way to revive used nuts and bolts [Re: JohnRR] #3243867
07/12/24 10:51 AM
07/12/24 10:51 AM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I am try to clean up some lightly rusted Super Trick nuts bolts and washers. I’m hoping to retain their original color when I’m done. Thanks everyone.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: BloFish] #3243898
07/12/24 12:33 PM
07/12/24 12:33 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Don't leave them in evaporust for a long time , 1/2 hour at a time .
Re: Best way to revive used nuts and bolts [Re: JohnRR] #3243903
07/12/24 01:03 PM
07/12/24 01:03 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
As long as it stays below the surface it shouldn't harm anything. The top surface is very active so it will leave an etch line if the parts are not fully submerged. That is about the only negative I've learned when using it so far.
I had some used chrome bumper guards that were rusty as can be on the backsides and I let them sit in Evaporust for weeks and it removed all the rust and didn't harm the chrome at all.
I've done the vinegar thing as well, but if you don't neutralize it you'll end up with an orange fog all over the parts again in a few hours. Same thing with muriatic acid. I stopped using that years ago as the fumes are off the charts. 💀
Re: Best way to revive used nuts and bolts [Re: Neil] #3243923
07/12/24 02:46 PM
07/12/24 02:46 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I went ahead and began soaking them in white vinegar since I had plenty on hand. When you say to neutralize it Neil after soaking them, I assume you mean in plain water?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: BloFish] #3243924
07/12/24 02:50 PM
07/12/24 02:50 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Baking soda and water mixed.
Re: Best way to revive used nuts and bolts [Re: Neil] #3243929
07/12/24 03:10 PM
07/12/24 03:10 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: BloFish] #3244097
07/13/24 11:34 AM
07/13/24 11:34 AM
moparx Offline
moparx  Offline
i have so many cans and bins full of nuts and bolts saved over 60 years or so, i should just toss 'em all and buy new ones when i need one. biggrin
but of course i can't bring myself to do it............ panic
beer
Re: Best way to revive used nuts and bolts [Re: moparx] #3244105
07/13/24 12:15 PM
07/13/24 12:15 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Neither can I, buying new is a last resort for me.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: moparx] #3244126
07/13/24 01:08 PM
07/13/24 01:08 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
beer
Don't do it. I moved twice in two years, and gleaned down my coffee cans full of nuts and bolts....Just the other day I needed just two nuts and bolts, that would have been in the cans, but alas I had to drive to the Hardware store.... flame
Let your inheritors be the ones who throw them away..... up
My Monster are real!
Living within your means makes life pretty easy.
Re: Best way to revive used nuts and bolts [Re: 67vertman] #3244158
07/13/24 03:10 PM
07/13/24 03:10 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
24 hours later… I may go another day and see how they look.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: BloFish] #3244165
07/13/24 04:00 PM
07/13/24 04:00 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I use lye to degrease my dirty iron and then use white vinegar for rust removal. Cheap and effective. thumbs
Re: Best way to revive used nuts and bolts [Re: John Brown] #3244380
07/14/24 10:46 AM
07/14/24 10:46 AM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
They’re done.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to revive used nuts and bolts [Re: 67vertman] #3244444
07/14/24 03:43 PM
07/14/24 03:43 PM
moparx Offline
moparx  Offline
beer
my "inheritors" already hate me for having too much "stuff". laugh2
beer
Re: Best way to revive used nuts and bolts [Re: moparx] #3244513
07/14/24 07:54 PM
07/14/24 07:54 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
I couldn't figure out how to post the image, so here's the link. Kinda funny IMHO.
www.reddit.com/r/ChildofHoarder/comments/nrmy4c/humor_one_day_all_this_will_be_yours/
