Re: New tires for my 2015 SRT
[Re: cudaman1969]
#3243710
07/11/24 04:30 PM
07/11/24 04:30 PM
Posts: 8,184 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Something to consider. Stopping distance. The following was copied from Quora
"High mileage tires are designed to last longer by using harder rubber compounds and different tread designs compared to regular tires. While they do offer excellent durability and longevity, they may sacrifice some level of comfort and performance compared to tires with softer compounds or specialized designs.
Ride Comfort: High mileage tires may not provide the same level of comfort as softer tires because the harder rubber compound used in high mileage tires can result in a firmer ride. So, if ride comfort is your top priority, you may want to consider this trade-off. Handling and Performance: High mileage tires may not offer the same level of grip and handling performance as tires with softer compounds. If you prioritize performance and handling, you might find that high mileage tires are not the best choice for your driving needs. Durability and Longevity: High mileage tires excel in terms of durability and longevity. If you do a lot of driving and want tires that will last a long time, high mileage tires can be a good option. Driving Conditions: Consider the driving conditions you typically encounter. If you drive mostly on smooth highways and prioritize longevity over ride comfort, high mileage tires could be a good choice. However, if you frequently drive on rough roads or in inclement weather, you might prefer tires that offer better traction and handling. Ultimately, the decision between high mileage tires and tires that prioritize comfort will depend on your driving preferences and priorities. If you value longevity and durability over ride comfort and performance, high mileage tires could be a good fit for your needs. However, if ride comfort and performance are more important to you, you may want to explore other tire options that better suit your preferences."
[Re: moparjim79]
#3243970
07/12/24 05:47 PM
07/12/24 05:47 PM
Posts: 1,296 Loudoun County, VA
Brad_Haak
Loudoun County, VA
SRT... Challenger?
Wheel size?
Summer performance or all-weather performance (but definitely not talking snow tires) or all-weather daily-driver?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: cudaman1969]
#3244067
07/13/24 07:07 AM
07/13/24 07:07 AM
Posts: 5,982 Greenville, PA
redraptor
Greenville, PA
I had asked before but can’t remember the answers. I want a long lasting tire, not for racing, what do y’all suggest? Don’t have size off hand but they’re to low profile, ( 20?) Mine are 275/40/20. I have Michelin all season 4.
[Re: moparjim79]
#3244109
07/13/24 12:28 PM
07/13/24 12:28 PM
Posts: 3,557 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Continental. You won't regret it. Granted this was a while ago but my Magnum came with Continental Tires, they lasted 40,000 miles and I had no problems with them. I replaced them with a set of Michelins that lasted 86,000 miles. Those were replace recently at 60,000 miles but mostly because of age, they still had quite a bit of tread. The first 170,000 miles or so included a lot of road miles, mostly city since then, the car now has close to 190,000.
