Re: 14" trim rings
[Re: tboomer]
#3243624
07/11/24 08:52 AM
07/11/24 08:52 AM
Posts: 3,538 Lansing, MI
70gtx440dana
Lansing, MI
69 rings only have 4 retention clips. 70 and later had clips around the entire circumference.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 14" trim rings
[Re: 70gtx440dana]
#3243709
07/11/24 04:29 PM
07/11/24 04:29 PM
Posts: 21,667 N.E. OHIO, USA
A12
N.E. OHIO, USA
69 rings only have 4 retention clips. 70 and later had clips around the entire circumference. No difference in finish for '69/'70 is this correct besides the number of retention clips? What had the polished finish versus the brushed finish?
Re: 14" trim rings
[Re: Neil]
#3243766
07/11/24 09:02 PM
07/11/24 09:02 PM
Posts: 21,724 It's a dry heat
gtx6970
It's a dry heat
I think all the 14" Mopar wheel trim rings were brush finished??? Correct, brushed face with a polished outer lip on both
Re: 14" trim rings
[Re: A727Tflite]
#3243767
07/11/24 09:13 PM
07/11/24 09:13 PM
Posts: 3,158 Michigan
A727Tflite
Did all production trim rings have part numbers?
Whether a decal applied or part number stamped in? I’ll ask again, anyone?
Re: 14" trim rings
[Re: topside]
#3243772
07/11/24 09:35 PM
07/11/24 09:35 PM
Posts: 26,244 United Socialist States of Ame...
tboomer
My original '69s with 14" Road Wheels (Magnums) were brushed, with polished outer (vertical) flange. 14" road wheels would look cool! I just learned something here! Thanks! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: 14" trim rings
[Re: A727Tflite]
#3243783
07/11/24 10:10 PM
07/11/24 10:10 PM
gtx6970
It's a dry heat
Whether a decal applied or part number stamped in? I’ll ask again, anyone? There is / was a decal on the backside These are 1969 Rings ONLY
Re: 14" trim rings
[Re: formula_s]
#3247207
07/25/24 11:22 AM
07/25/24 11:22 AM
Posts: 862 Avondale AZ
Prodart440
Avondale AZ
I have 6 trim rings. Four of them are the same, and the other two have a lip at the inner part, but not like what is pictured above. It seem like they are 1/16" or so "taller" than the other four.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
