Tuff wheel recommendations #3242645
07/06/24 09:52 AM
07/06/24 09:52 AM
St. Louis, Mo
3
318 Stroker Offline OP
St. Louis, Mo
I'm looking to buy a repro Tuff wheel. Would like the same 14 1/2 diameter as the original factory wheel and hopefully padded like the originals. The repros I've seen have a rock hard rim. Any suggestions?
Re: Tuff wheel recommendations [Re: 318 Stroker] #3242689
07/06/24 02:26 PM
07/06/24 02:26 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Grant makes a reproduction that's dead nuts correct. I had one on my Duster.
https://www.classicindustries.com/p...150179a66901d79adebecd8&gclsrc=3p.ds
Re: Tuff wheel recommendations [Re: Kudakidd] #3242694
07/06/24 02:43 PM
07/06/24 02:43 PM
St. Louis, Mo
3
St. Louis, Mo
I see the descriptions says foam grip. Am I to assume it has a liile give to the grip, instead of the very hard grip on others I've seen?
Re: Tuff wheel recommendations [Re: 318 Stroker] #3242698
07/06/24 03:05 PM
07/06/24 03:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Honestly I have yet to see one dead nuts on. Some are closer than others though. I don`t like the hard grip on the one I have.
Re: Tuff wheel recommendations [Re: mopars4ever] #3242705
07/06/24 03:29 PM
07/06/24 03:29 PM
St. Louis, Mo
3
St. Louis, Mo
Yes as I mentioned, I don't like the hard grip. I'd like to confirm that it has a little cushion to it before I buy it. I see it's a 15" OD as opposed to the 14 1/2" on the original. I could probably live with the extra 1/4" all the way around
Re: Tuff wheel recommendations [Re: 318 Stroker] #3242717
07/06/24 06:14 PM
07/06/24 06:14 PM
CrazyD Offline
CrazyD  Offline
There is a customer review of the Grant Tuff Wheel posted on the Classic Industries website which stated it was hard outside rubber, "not soft at all"
Re: Tuff wheel recommendations [Re: CrazyD] #3242724
07/06/24 07:15 PM
07/06/24 07:15 PM
St. Louis, Mo
3
St. Louis, Mo
That's been my experience with the Grant wheel in the past.
Re: Tuff wheel recommendations [Re: 318 Stroker] #3242767
07/06/24 10:15 PM
07/06/24 10:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Tuff wheel recommendations [Re: mopars4ever] #3242784
07/06/24 11:49 PM
07/06/24 11:49 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I bought a GT Performance Retro Tuff wheel on Ebay a couple years ago for $250 for my Challenger..
I used my old Rim Blow center cap as a horn button.
GT Retro Tuff Design Wheels
Re: Tuff wheel recommendations [Re: Kudakidd] #3242978
07/08/24 09:13 AM
07/08/24 09:13 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Well "dead nuts" is about 90% . . . the repro wheel has the "formed lines" on wheel, facing the driver . . . where as OE wheels, had "single line" running around inside of the grip . . . other than that, they are GREAT ! Only see the difference when have both together . . .
Re: Tuff wheel recommendations [Re: a12rag] #3242981
07/08/24 09:27 AM
07/08/24 09:27 AM
K
Kiddart Offline
Kiddart  Offline
K
I bought the Grant for my 72 Demon, it was close enough to score well at Autorama this last year!!
Thank you
Kiddart
Re: Tuff wheel recommendations [Re: RTSE4ME] #3243049
07/08/24 03:35 PM
07/08/24 03:35 PM
St. Louis, Mo
3
St. Louis, Mo
This one seems to be the closest to what I'm looking for.
Re: Tuff wheel recommendations [Re: mopars4ever] #3243050
07/08/24 03:39 PM
07/08/24 03:39 PM
St. Louis, Mo
3
St. Louis, Mo
I also need to check this one out. I've ruled out the Grant wheel.
Re: Tuff wheel recommendations [Re: 318 Stroker] #3243106
07/08/24 09:39 PM
07/08/24 09:39 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I looked at all the pics - they look OK, but not even close to "dead nuts." I have two of them that look like NOS & they are both originals - one of them I took off a car - I don't even remember what it was. The other one I bought off someone many years ago - back in the 80's - I know the guy said it came off a Dodge van. When they are perfect, they are shiny - like coated with a clear lacquer. And they are nice & spongy, not exactly soft, but not hard. They are kick-a$$ steering wheels & have a VERY nice feel when driving. I bought a 30,xxx mile all original 1975 Roadrunner back in 1985 from a car lot in AZ. & the Tuff wheel was covered in a steering wheel cover probably since day 1. I took the cover off & the steering wheel was like absolute new. It felt outstanding. I understand why these are so sought after! I plan on using both of mine on my Cudas.
Re: Tuff wheel recommendations [Re: Sunroofcuda] #3243509
07/10/24 04:14 PM
07/10/24 04:14 PM
MN
Droop69 Offline
Droop69  Offline
MN
I would recommend buying a nice original. They are out there just beat the bushes you will find one!
Re: Tuff wheel recommendations [Re: Droop69] #3244044
07/13/24 06:30 AM
07/13/24 06:30 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I saw a pretty decent one at Carlisle for $250 with the can, $200 w/out.
Re: Tuff wheel recommendations [Re: 1fastrunner] #3244076
07/13/24 09:54 AM
07/13/24 09:54 AM
St. Louis, Mo
3
St. Louis, Mo
Any chance you have a swap space number? My friend is there now.
Re: Tuff wheel recommendations [Re: 318 Stroker] #3244078
07/13/24 10:04 AM
07/13/24 10:04 AM
1fastrunner Offline
1fastrunner  Offline
Sorry, guessing H or lower letter row. Maybe C?
On the left side as you walk from the main gates
He had 2, the one I mentioned was better than the other. I almost bought it knowing someone was looking, but no guarantee it would be what he wanted.
Re: Tuff wheel recommendations [Re: Kudakidd] #3244106
07/13/24 12:17 PM
07/13/24 12:17 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
looks decent from a distance but is far from dead nuts on. its hard rubber. had one in my old dart. i liked it but it was quite sticky out of the box. after a few cleanings it was ok.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Tuff wheel recommendations [Re: abodyjoe] #3244422
07/14/24 01:58 PM
07/14/24 01:58 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Incorrect dish, wrong spoke cover length, wrong finish, wrong center cap, no foam, wrong diameter wheel, wrong diameter of grip......
It's a simple round piece of metal cut by a machine, with foam glued to it: ffs's what is so hard about doing an exact copy of an original? Especially for the price they are asking. shruggy
Mo' Farts
Moderated by "tbagger".
