Re: Mapp gas to heat up bearing race?
[Re: Neil]
#3242438
07/04/24 07:09 PM
07/04/24 07:09 PM
Posts: 9,949 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Do you have a welder there? You can also heat the race with that. OR can you cut a couple small grooves in it with a drem tool and small cutoff wheel and then whack it with a chisel as it will snap apart. Umm air compressor and die grinder with a small cutter?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3242443
07/04/24 07:25 PM
07/04/24 07:25 PM
Posts: 4,953 new berlin wisconsin
Mr T2U
i would support the spindle with something, then use a SHARP chisel and hit the race in 180* offsets. then 90* to the earlier 2 if needed. . the race should shatter and almost fall off after the first 2 impacts 80% of the time. i do this with rear 8 3/4 axles bearing retainers all of the time.
perception is 90% of reality
[Re: Mr T2U]
#3242445
07/04/24 07:46 PM
07/04/24 07:46 PM
Posts: 26,244 United Socialist States of Ame...
tboomer
Thanks guys...It's still on the car yet...I do have a small welder here at home and a die grinder. The dremel is a rechargeable but pretty weak. The smallest disc for the die grinder that I can find locally id 3"..
[Re: tboomer]
#3242447
07/04/24 08:22 PM
07/04/24 08:22 PM
Posts: 10,912 North Dakota
6PakBee
North Dakota
I didn't change the head when I went from propane to MAAP. Maybe I should have but the flame visually looks good so..........
Just throwing this out there, if it was me I'd weld two pieces of Redi-Rod to the race and use a steering wheel puller to pull it off. Just a thought.
[Re: tboomer]
#3242466
07/04/24 09:15 PM
07/04/24 09:15 PM
Posts: 75,265 A gulag near you.
JohnRR
A gulag near you.
Thanks guys...It's still on the car yet...I do have a small welder here at home and a die grinder. The dremel is a rechargeable but pretty weak. The smallest disc for the die grinder that I can find locally id 3".. Ted I had the same thing happen years ago , I used the dremel thin disc and chisel method.
Mainstream Media is the new Pravda
[Re: tboomer]
#3242482
07/04/24 11:33 PM
07/04/24 11:33 PM
Posts: 20,265 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have an inner bearing race stuck tight on the spindle on my 69 Dart..I bought a yellow bottle of Mapp gas in an attempt to heat it enough so can pull it off with channel locks..I am not having much success and my grandson tells me there is a special head to use with Mapp gas instead of a propane head like I tried to use. Suggestions please? Thanks! Ted Ted if you have an Oriellys, Auto Zone, Advance Auto or many more you can borrow a puller. Yank that son of a gun off.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Mr T2U]
#3242543
07/05/24 12:15 PM
07/05/24 12:15 PM
Posts: 615 Boise
Moparteacher
Boise
i would support the spindle with something, then use a SHARP chisel and hit the race in 180* offsets. then 90* to the earlier 2 if needed. . the race should shatter and almost fall off after the first 2 impacts 80% of the time. i do this with rear 8 3/4 axles bearing retainers all of the time. DO NOT USE A CHISEL ON A BEARING RACE! Unless you like very sharp shards of splintered metal shattering in your direction. This is shop safety 101. You can cut, heat, and use a flay chisel to budge the race down the stem once you've loosened it's grip. You're MAP gas isn't producing enough heat. I would try an inductive heat gun, if you have access or follow one of the other suggestions.
[Re: rustbuckett68]
#3242591
07/05/24 05:28 PM
07/05/24 05:28 PM
Posts: 20,318 Park Forest, IL
slantzilla
Park Forest, IL
Use your welder to put down a bead around the outer part of the race. The heat will expand the race, and it will almost fall off. Works the same on inner races too, will shrink the race and fall out. THIS/\
[Re: Moparteacher]
#3242599
07/05/24 07:38 PM
07/05/24 07:38 PM
Posts: 43,804 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
i would support the spindle with something, then use a SHARP chisel and hit the race in 180* offsets. then 90* to the earlier 2 if needed. . the race should shatter and almost fall off after the first 2 impacts 80% of the time. i do this with rear 8 3/4 axles bearing retainers all of the time. DO NOT USE A CHISEL ON A BEARING RACE! Unless you like very sharp shards of splintered metal shattering in your direction. This is shop safety 101. You can cut, heat, and use a flay chisel to budge the race down the stem once you've loosened it's grip. You're MAP gas isn't producing enough heat. I would try an inductive heat gun, if you have access or follow one of the other suggestions. When you are on the road and only have a hammer and chisel it works very well! Never had it shatter and spray metal at me, usually a couple hits with the chisel breaks it with no damage to the spindle... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
JB Rhinehart, Realist
A-Body's RULE!
