2020 Featherlite 4410 24 foot enclosed hauler
[Re: Azzkikrcuda]
#3247286
07/25/24 04:29 PM
07/25/24 04:29 PM
Posts: 138 ca
Swingin70
ca
No longer racing unfortunately, selling the enclosed trailer. Darn near new, very little use. New today this trailer retails for $54K from Featherlite asking $42K OBO . Willing to assist with delivery.
2020 Featherlite 4410 8.5 x 24 Car / Racing Trailer with rear ramp door Upgraded with: lined walls & ceiling upper and lower cabinets 30 Amp motorbase Aluminum wheels in addition to the many standard features listed below:
OVERVIEW Featherlite enclosed bumper pull car trailer Model 4410 offers functionality, durability and value for custom car owners and racers. Featherlite's newest car hauler design features a spread axle, rear spoiler and flat nose. This car trailer, available in lengths of 20', 24' or 28', has a rear ramp and camper door standard to make accessing your cargo easy in this great looking, durable car trailer. While options are more limited on the Model 4410.
HIGHLIGHTS Lengths of 24' Width of 8'6" Flat nose & spread axle design Aluminum Floor Standard Rear ramp with cable assist Inside height of 7'0" Sleek Rivetless Design
SPECS & FEATURES Model: 4410 Hitch Type: Bumper pull Wall to Wall Width: 99" (rear opening width = 94 1/4") Fender to Fender Width: 82" Inside Height: 7'0" Loading Height: 20" Axles: Two rubber torsion 6000# axles with electric brakes Tire/Rim: 16" 6-hole silver aluminum wheels with Goodyear ST235/80R16 Load Range E tires (Qty: 4) Tie Downs: Stainless steel swivel "D" ring tie downs (Qty: 4) Floor: Smooth extruded aluminum floor Side Door: 42" heavy-duty 2" double sealed door on curbside Ramp: Full height & width rear ramp with cable assist, pressure latches, treadplate & vinyl hinge cover Coupler: 2 5/16" coupler; Crank type jack with wheel Exterior: White exterior sheets; Flat nose with stainless steel vertical & center panel; Spread axle design with drop skirt and fenderettes; Polished aluminum cast corners Exterior Lighting: Rear spoiler with load light; Clear LED clearance lights; Slimline LED stop/turn lights (Qty: 4) Interior Lighting: 6 Surface-mount LED dome lights with switch inside 36" beavertail Spare tire carrier 2- 14" x 14" crank up roof vents Skid plate Custom Winch
Hellcat oil pump
[Re: Swingin70]
#3247681
07/27/24 02:43 PM
07/27/24 02:43 PM
Posts: 1,855 NW Indiana
fbs63
NW Indiana
Mopar Hellcat oil pump. New in packaging. Only mocked up on engine. $130 shipped. PM me here. Located in NW Indiana SOLD!
Hemi Tunnel Ram and Carbs
[Re: moparts]
#3248004
07/28/24 10:48 PM
07/28/24 10:48 PM
Posts: 441 montana
BANDIT
montana
For Sale; Vintage Weiand tunnel ram and carbs. Intake appears to have Direct Connection part numbers on base and top plate. It has some openings cut in it for cooling?? Bolt holes look good. Carbs are 1050, 3 circuit pieces from approx the same era. Pulled all the bowels off, real clean inside. They do need kits. Part numbers are in pictures. $1500.00 OBO. Call 406-489-3534 for more info and pictures. Thanks for add!
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 1980 Plymouth Arrow 572 Hemi. 242" Mullis Dragster. 6.90@ 200mph
Hooker headers J-Bends - NEW
[Re: moparts]
#3248073
07/29/24 10:13 AM
07/29/24 10:13 AM
Posts: 150 Albert Lea, MN
GTX5877
Albert Lea, MN
NEW Hooker Headers exhaust parts:
#12540 1-5/8" J-bends, 6" x 15", 2.5" radius, 18 gauge.
$18 each -- buy 5 or more at $15 each
NEW Hooker #12560 1-7/8" J-Bends, 6" x 15", 3" radius, 18 gauge.
$20 each--buy 5 or more at $17 each
J-Bends are used for fabricating or modifying existing header tubes for performance and race cars.
Can ship, buyer pays shipping and fees.
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
Smal Block Racer Brown STX-21 Solid Flat Tappet Cam - New
[Re: bremotorsports]
#3249100
08/02/24 08:52 PM
08/02/24 08:52 PM
Posts: 908 CT
Rocket
CT
I have a new Racer Brown STX-21 solid flat tappet cam. I bought several of these for bracket racing. I am no longer racing so this cam is up for sale. Specs with 1.5 ratio rockers are 560" lift and 272 degrees of duration at 0.050" lift intake and exhaust. LSA is 105 degrees. Great bracket racing cam.
Price is $230 shipped in the lower 45 states.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Howard's Solid Lifter Cam for Mopar Dodge Plymouth Big Block
[Re: moparts]
#3249113
08/02/24 09:56 PM
08/02/24 09:56 PM
Posts: 5,724 Detroit area
6PAX
Detroit area
For sale is a Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping or I can deliver to the Nats if paid for in advance. I also have a new set of Comp Cams inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $45 for. https://www.summitracing.com/parts/HRS-CL722322-08https://www.howardscams.com/mechanical-flat-tappet-camshaft-lifter-kit-1959-1980-chrysler- show contact info -7600-howards-cams https://www.summitracing.com/parts/cca-973-16gt340 at yahoo.com
Small Block I Beam Connecting Rods by Childs & Albert - New
[Re: 6PAX]
#3249506
08/04/24 08:48 PM
08/04/24 08:48 PM
Posts: 908 CT
Rocket
CT
I have a new set of forged I beam connecting rods by Childs & Albert in the original box. American made in the 1990’s. Part number is 340-15B-2. Center to center length is 6.125”. Big end is for small block rod journals of 2.125” and small end is for pins of 0.927”. Weight per rod is ~ 685 grams. See spec card in the pictures.
These are very stout rods, suitable for a high horsepower build.
Price is $850 shipped. I will ship internationally for the added cost.
Barton intake & dominator carb
[Re: galen]
#3249637
08/05/24 02:52 PM
08/05/24 02:52 PM
Posts: 859 Missouri
galen
Missouri
Ray barton 16 bolt hemi dominator intake. Never ran, no modifications. 550$ you pay shipping. New Holley 1050 red ultra dominator. Has never had fuel in it or tampered with. Not sure if I have original box. 750$ plus ride. PM with questions etc. I will give you my number. Carburetor sold. Still have intake manifold.
Holley 12-846 HP Billet Fuel Pressure Regulator NEWtor "NEW
[Re: moparts]
#3251465
08/14/24 06:36 PM
08/14/24 06:36 PM
Posts: 248 Northwest Indiana
19Coronet66
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8AN o-ring outlet. -6AN o-ring return. $175 shipped in the 48 states. PM if interested. https://www.jegs.com/i/Holley/510/12-846/10002/-1
(NEW) ARC SWITCH CONTROL PANEL #3701
[Re: Al_Alguire]
#3252042
08/17/24 12:40 PM
08/17/24 12:40 PM
Posts: 6,402 Heaven
EvilB1Dart
Heaven
ARC SWITCH CONTROL PANEL #3701 / Part number is provided if you need details.
Brand new never mounted. Forgot I had it.
Accept PayPal or personal check or money order. Your choice.
$225 shipped to your door in the U.S.
PM me if you want it. Thanks Moparts!
"Any fool can know. The point is to understand"
- A. Einstein
