Re: Mapp gas to heat up bearing race?
[Re: tboomer]
#3242763
07/06/24 10:01 PM
07/06/24 10:01 PM
Posts: 655 MN
astrobuf
MN
MAPP needs a different amount of air (more) to burn properly. MAPP rated torches get their max heat when thecair/fuel ratio is correct.
However
Most MAPP Torches are not designed to put out enough heat to warm up a spindle. With actually heat source, you are heating up the spindle as fast as your are heating the bearing race, so no joy there.
You might try slitting the race part way through with a dremel cutoff and carefully Chisel it apar
An oxy-acetylene torch would makecshort work of this, but I imagine that is out of your budget.
Astrobuf
So, are you really a Rocket Scientist?
[Re: astrobuf]
#3242800
07/07/24 08:08 AM
07/07/24 08:08 AM
Posts: 26,269 United Socialist States of Ame...
tboomer
However
Astrobuf I worked on it with a cutting wheel and a chisel. I may have ruined my spindle...I have been having a stroke of bad luck! Why would you think a torch is out of my budget? I have never had a use for one till now.
[Re: tboomer]
#3242808
07/07/24 09:53 AM
07/07/24 09:53 AM
Posts: 10,926 North Dakota
6PakBee
North Dakota
I worked on it with a cutting wheel and a chisel. I may have ruined my spindle...I have been having a stroke of bad luck! Why would you think a torch is out of my budget? I have never had a use for one till now. I was afraid that was going to happen. A person who knows what they are doing makes anything look easy, others trying it for the first time...... I will repeat myself, weld a couple pieces of all thread on the bearing race and pull it off with a steering wheel puller. A low risk solution.
[Re: tboomer]
#3242848
07/07/24 02:49 PM
07/07/24 02:49 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
However
Astrobuf I worked on it with a cutting wheel and a chisel. I may have ruined my spindle...I have been having a stroke of bad luck! Why would you think a torch is out of my budget? I have never had a use for one till now. Ted a couple of nicks are no big deal just make sure you file off any high spots. Once everything is assembled the inner race does not turn on the spindle.
Mainstream Media is the new Pravda
[Re: TJP]
#3243195
07/09/24 11:25 AM
07/09/24 11:25 AM
tboomer
Thanks John! I am gonna take a few days off away from the car... Sometimes that's the best approach. if you're concerned about the spindle post a pic probably OK 🍻 Thanks TJP! I thought that I would put new brake shoes on...Simple task,right? My hands are old and weak...I can't get the springs back on....I quit!
[Re: tboomer]
#3243202
07/09/24 11:34 AM
07/09/24 11:34 AM
Posts: 10,021 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Where are your younger car friends at? Someone can clearly step up and help you. Getting older blows the "Golden Years" myth out of the water. Not much golden about it imo.
Are you using the std. universal brake tool or just trying to stretch with pliers?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3243217
07/09/24 12:25 PM
07/09/24 12:25 PM
Posts: 20,212 north of coder
moparx
gettin' old ain't for sissies ! [or the "stronger" language of your choice ! ] i get so frustrated these day just doing simple things that i have done hundreds or thousands of times, only finding it's almost impossible for me these days, and when i'm done, i feel like i got run over by a truck or beat by a "studio rassler" ! one project i'm going to do pretty directly, is make a replacement saddle for my one floor jack, [aluminum jack of course, because i can't "rassle" my steel jacks around very good anymore ! ] that will look kind of like a two pronged fork. it will "cradle" an upright standing tire/wheel, and i can therefore pick up and install the assembly WAY easier than i can now, by just picking it up myself. the "forks" being made of solid round rod welded to a "drop style" saddle that will have a post on the bottom that fits the jack, will have a couple of pieces of electrical conduit [retained on the solid round rod, one inch, maybe 3/4, by a washer slightly larger than the conduit's OD welded to the end of the round rod] that will allow the tire/wheel to "roll", thus aligning the lug studs so the tire/wheel assembly can then be pushed onto the studs. this gotta' be better than me fumbling around trying to lift and align the bolt pattern, wearing me out in the process !
[Re: Mr PotatoHead]
#3243293
07/09/24 05:12 PM
07/09/24 05:12 PM
tboomer
Are you using the std. universal brake tool or just trying to stretch with pliers? I have the correct pliers.. One of the young guys is gonna stop by Friday after work...He's a mechanic by trade. I take him and his boys target shooting.
[Re: slantzilla]
#3243578
07/10/24 11:36 PM
07/10/24 11:36 PM
Posts: 15,819 Omaha Ne
TJP
Omaha Ne
Use your welder to put down a bead around the outer part of the race. The heat will expand the race, and it will almost fall off. Works the same on inner races too, will shrink the race and fall out. THIS/\ Good idea. welding studs as someone else suggested to pull it off may do the same. I've cut and split 100's with a pnuematic cutting wheel and chisel.
[Re: Mr PotatoHead]
#3243584
07/11/24 12:41 AM
07/11/24 12:41 AM
Posts: 533 SW CO
HemiSportFury
SW CO
Getting older blows the "Golden Years" myth out of the water. Not much golden about it imo. The Golden Years are like watching a golden sunset. Comes and goes in an instant.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
