drag time duster ? #324201
05/21/09 12:36 AM
05/21/09 12:36 AM
littlestown pa
dustpan man Offline OP
littlestown pa
i got a 75 duster that i lightend put a 360 in it its got a 474 lift cam fullyported magnum heads an rpm air gap 10 to 1 compresion a 904 323 gears i think it ways 3100lb just a question its not dun yet i want to put 355 sure grip in it and a 3000 stall
Re: drag time duster ? [Re: dustpan man] #324202
05/21/09 07:35 AM
05/21/09 07:35 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Both a good idea. What do you intend to do with it??
Re: drag time duster ? [Re: Dodgem] #324203
05/21/09 11:21 AM
05/21/09 11:21 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Going from 3.23 to 3.55 isn't going to make much difference. Not enough to warrant the expense in my opinion.
Re: drag time duster ? [Re: stumpy] #324204
05/22/09 01:07 AM
05/22/09 01:07 AM
littlestown pa
littlestown pa
i wanted to make it show and go and i was just wanderin what times u think it would do
Re: drag time duster ? [Re: dustpan man] #324205
05/22/09 08:24 AM
05/22/09 08:24 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
mid 13's
Re: drag time duster ? [Re: MoparforLife] #324206
05/22/09 11:03 AM
05/22/09 11:03 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it isn't going to be a daily driver I would go to 3.91 gears. You will get better performance then with the 3.55s
