For Sale/ Wanted - Small Block Engine - 3rd Quarter
#3241609
06/30/24 09:10 PM
06/30/24 09:10 PM
Posts: 15,588 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale/ Wanted - Small Block Engine - 3rd Quarter
[Re: moparts]
#3242463
07/04/24 09:11 PM
07/04/24 09:11 PM
Posts: 5,723 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
W2 Small Block Head Costings - New
[Re: Rocket]
#3242731
07/06/24 07:31 PM
07/06/24 07:31 PM
Posts: 908 CT
Rocket
CT
I have a pair of new individual W2 race head casting number P5249769. These heads have no machining performed. As delivered by Mopar including 3/8” iron valve guides and closed chambers. These heads require the use of T&D or Jesel rocker systems.
Price is $1,200 for the set plus shipping.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block Roller Rocker Kit 1.6 Ratio - New
[Re: Rocket]
#3242733
07/06/24 07:36 PM
07/06/24 07:36 PM
Posts: 908 CT
Rocket
CT
I have a new PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $510 shipped in the lower 48 states.
Factory Small Block Valve Covers 318,340,360
[Re: Memongo]
#3243591
07/11/24 05:43 AM
07/11/24 05:43 AM
Posts: 4,355 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
Factory Small Block Valve Covers 318,340,360, Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only! Call Steve 810-629-1097
Note: All Harness, Wire Brackets Intact!
P4120484 Fuel Pump Eccentric Small Block 273, 318, 340, 360
[Re: Memongo]
#3243599
07/11/24 05:50 AM
07/11/24 05:50 AM
Memongo
Parts peddler
Parts peddler
Fenton, MI
P4120484 Fuel Pump Eccentric Small Block 273, 318, 340, 360. Used, $20 + Shipping, Payment via US Postal Money Order Only!. Shipping: US Address Only! Call Steve 810-629-1097
