For Sale/ Wanted - Big Block Engine - 3rd Quarter
#3241607
06/30/24 09:08 PM
06/30/24 09:08 PM
Posts: 15,588 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale/ Wanted - Big Block Engine - 3rd Quarter
[Re: moparts]
#3241689
07/01/24 12:27 PM
07/01/24 12:27 PM
Posts: 7,895 Witness Protection Program
Kudakidd
Carter AVS carburetor. PN 4966S Square bore carb. Should fit 383-440 big block engines. Rated at 625 cfm. Everything moves freely including the float. As usual it could probably use a rebuilding. $50. INCLUDES shipping. Price does not include the carb stand.
[Re: moparts]
#3242199
07/03/24 04:10 PM
07/03/24 04:10 PM
Posts: 3,017 Sac, CA
mopowers
Sac, CA
Sold
[Re: moparts]
#3242461
07/04/24 09:10 PM
07/04/24 09:10 PM
Posts: 5,723 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
73-74 Electric Choke #3656730 All Models, Used, $30 + Shippi
[Re: Memongo]
#3243798
07/11/24 10:32 PM
07/11/24 10:32 PM
Posts: 4,355 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
73-74 Electric Choke #3656730 All Models, Used, $30 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097 , Used, $30 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097
