Adapters to replace water pump on Hemi with hoses
#3240991
06/27/24 11:58 PM
06/27/24 11:58 PM
Posts: 7,502 Minnesota
Hemi_Joel
Minnesota
Hi, does anyone make adapters to put hose fitting on the water inlet and outlet ports on the block where the water pump was removed for use with a remote electric pump? I know I saw them somewhere years ago, but can't find them searching on line. THanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Adapters to replace water pump on Hemi with hoses
[Re: Hemi_Joel]
#3240993
06/28/24 12:00 AM
06/28/24 12:00 AM
Posts: 43,375 Bend,OR USA
Cab_Burge
Maybe AndyF company AR Engineering scope:
[Re: gregsdart]
#3241042
06/28/24 09:22 AM
06/28/24 09:22 AM
Hemi_Joel
Minnesota
This is for a gen 2, 426. Thanks!
[Re: Hemi_Joel]
#3241091
06/28/24 12:33 PM
06/28/24 12:33 PM
Posts: 31,117 Oregon
AndyF
Hi, does anyone make adapters to put hose fitting on the water inlet and outlet ports on the block where the water pump was removed for use with a remote electric pump? I know I saw them somewhere years ago, but can't find them searching on line. THanks, Joel I used to sell water manifold blocks but I don't anymore. I sold the design to Indy so check with them.
[Re: '72CudaRacer]
#3241246
06/29/24 12:11 AM
06/29/24 12:11 AM
AndyF
Indy sells the ones pictured in Andy F's picture. The problem with them is that there are no provisions to put a manual temp gauge sensor in (or any kind of sensor). Others may also be available.
Brian There is enough material to drill and tap for a sensor.
[Re: Cab_Burge]
#3241340
06/29/24 02:48 PM
06/29/24 02:48 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
FWIW I have used the Meziere stuff many times with no issues. I now have someone who can make them for me which is a but less $$
