Remote water pump RB #1914635
09/17/15 07:02 PM
09/17/15 07:02 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
What pump are you using for a remote water pump on a RB? I thought there was a post about this not too long ago, but I haven't been able to find it with the search.
Also, is #12 line large enough?
Thanks,
Brian
Re: Remote water pump RB [Re: '72CudaRacer] #1914780
09/17/15 11:26 PM
09/17/15 11:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well while you're waiting for legitimate information.... here's a pict of my old RB with it's Shogun waterpump and manifold (out of business). I never had a prob cooling, and it was nice having the room on the front of the car. If I could only find the picts after I cleaned things up..... smile
Mezier also has a couple styles of divorced water pumps. On has a fitting that welds on the tank of the radiator and the pump mounts there.
Re: Remote water pump RB [Re: '72CudaRacer] #1915007
09/18/15 11:54 AM
09/18/15 11:54 AM
AndyF Offline
AndyF  Offline
Meziere sells pumps. I'd use a custom radiator with the pump bolted directly to the radiator if you have the budget for it. That is a super clean setup.
On the engine side #12 hoses would probably be okay on the pressure side but I'd use #16 hoses on the outlet side.
Re: Remote water pump RB [Re: AndyF] #1915894
09/19/15 09:40 PM
09/19/15 09:40 PM
Mooresburg, Tn
Mooresburg, Tn
This is what I have to work with. It's a CSI system (old, over 20 years old), that the pump motor failed. It has this manifold to connect the block to the upper radiator hose and uses a small block Chevy pump to complete the system. If I use this with a remote pump connected to the lower radiator hose and split AN 16 hoses to this manifold, I can use a lot of what I already have and get the pump out of the way.
What options do I have for pumps that are reliable and not a small fortune?
Thanks, Brian
Re: Remote water pump RB [Re: '72CudaRacer] #1915999
09/20/15 07:18 AM
09/20/15 07:18 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I used the Meziere pump with 12 AN lines. Works good for me.
Re: Remote water pump RB [Re: '72CudaRacer] #1917181
09/22/15 12:18 AM
09/22/15 12:18 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I've had a Jabsco Centri-puppy on mine for over 20 years. It's a centrifugal pump made of brass and is plumbed with 3/4" hose. A couple of years after I installed mine Dedenbear came out with a version that would attach to a radiator hose.
