Dart Gen III block available?
#3239713
06/21/24 11:10 AM
06/21/24 11:10 AM
Posts: 1,897 Spahn Ranch
RMCHRGR
Spahn Ranch
Not sure if this is old news but seems like the Dart Gen III block is finally available. Splayed main caps but still looks promising. See the FB post below. Dart Gen III blockNothing listed on the Dart webpage yet, only a placeholder but the comments in the post say they can be ordered from Dart dealers. Currently a 4-month lead time.
'71 Duster '72 Challenger '17 Ram 1500
Re: Dart Gen III block available?
[Re: Dragula]
#3239878
06/22/24 07:37 AM
06/22/24 07:37 AM
Posts: 2,124 MD
RTSE4ME
MD
[Re: RTSE4ME]
#3240087
06/23/24 01:17 PM
06/23/24 01:17 PM
Posts: 12,481 Taxes & Virus's R-US, NY
Dragula
Well, that's not cheap....But the extra cubes would be nice...Does anyone recall how big they can build it? I remember 473 cubes is the biggest the normal way, and from there it needs a very special thrust bearing setup and crank to go 500 cubes.
Anyone got more info?
[Re: Dragula]
#3240216
06/24/24 05:24 AM
06/24/24 05:24 AM
Posts: 3,890 Smyrna, South Carolina
STEFF
Anyone got more info? 4.25 x 4.25
[Re: STEFF]
#3240581
06/25/24 09:12 PM
06/25/24 09:12 PM
RMCHRGR
Spahn Ranch
Didn't realize that was your post but put it together reading the comments. What's the goal with it?
[Re: RMCHRGR]
#3240622
06/26/24 05:31 AM
06/26/24 05:31 AM
STEFF
Didn't realize that was your post but put it together reading the comments. What's the goal with it? It's ll good. Plan is to make it either 431 or 442" and put a Procharger on it, F3D-106. Or, maybe a Roots Blower. The Dart block is too beastly to just build an NA combo.
[Re: STEFF]
#3241556
06/30/24 06:20 PM
06/30/24 06:20 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Facebook find today on weight
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Dart 500]
#3241647
07/01/24 05:38 AM
07/01/24 05:38 AM
STEFF
I assume thats the hellcat/BGE block but they did make a lighter one for the cars up until 2016 or 2017 (not as strong) when they all just used the hellcat/BGE for everything 6.4 or 6.2 It's a 6.4 Block I've been using since 2012. I do have to make a revision to the Stock Block weight as I mistakenly forgot to include the Main Caps and Studs.
[Re: RMCHRGR]
#3248947
08/02/24 09:24 AM
08/02/24 09:24 AM
Posts: 14 Quakertown PA
Tay
Quakertown PA
they are Nice piece ,
Non VVT block, 9.25 DH, with 4.25 , 4.30 Winberg crank, 1.88 pin, needed to clear the pan rail . (488ci) 6.1(c to c) rods, 1.0 Race tech Pistons, (put the piston .003 above deck in operation) 11 to 1 compression, 2.20 intake valve cleaned the bowl to match, then port matched to Drag pak intake , but other wise stock Apache heads, rockers arms and OEM lifters (for now) Purrs like kitten with cam motion GRIND# XA220/360 , may only be 1.65 Hp/CI at this point , but its' less than .600 lift cam and will idle for hours. bottom 2 inches of the water jacket are Hard blocked just for some add insurance against the god awful 1.42 Rod ratio.
[Re: Tay]
#3249111
08/02/24 09:48 PM
08/02/24 09:48 PM
Posts: 4,275 Canada
WO23Coronet
Canada
Non VVT block, 9.25 DH, with 4.25 , 4.30 Winberg crank, 1.88 pin, needed to clear the pan rail . (488ci) 6.1(c to c) rods, 1.0 Race tech Pistons, (put the piston .003 above deck in operation) 11 to 1 compression, 2.20 intake valve cleaned the bowl to match, then port matched to Drag pak intake , but other wise stock Apache heads, rockers arms and OEM lifters (for now) Purrs like kitten with cam motion GRIND# XA220/360 , may only be 1.65 Hp/CI at this point , but its' less than .600 lift cam and will idle for hours. bottom 2 inches of the water jacket are Hard blocked just for some add insurance against the god awful 1.42 Rod ratio. It makes 800hp with a 220/227@.050 cam?
[Re: WO23Coronet]
#3249973
08/07/24 07:20 AM
08/07/24 07:20 AM
Tay
Quakertown PA
Non VVT block, 9.25 DH, with 4.25 , 4.30 Winberg crank, 1.88 pin, needed to clear the pan rail . (488ci) 6.1(c to c) rods, 1.0 Race tech Pistons, (put the piston .003 above deck in operation) 11 to 1 compression, 2.20 intake valve cleaned the bowl to match, then port matched to Drag pak intake , but other wise stock Apache heads, rockers arms and OEM lifters (for now) Purrs like kitten with cam motion GRIND# XA220/360 , may only be 1.65 Hp/CI at this point , but its' less than .600 lift cam and will idle for hours. bottom 2 inches of the water jacket are Hard blocked just for some add insurance against the god awful 1.42 Rod ratio. It makes 800hp with a 220/227@.050 cam? typo, my bad 1.55/Hp/Ci(760hp, 9.20s@142-146MPH 2950 race weight Duster on 93oct ) ......keys are 2.20Intake valve/ bowl work and drag pak intake & Nick Williams 108mm tb , 1.35hp with out of the box Apache Heads/6.4SRT intake and OEM TB.
