Re: Torque Thrust lug nut torque
[Re: 6PAX]
#3237951
06/11/24 04:18 PM
06/11/24 04:18 PM
Posts: 22,783 Bitopia
jcc
Bitopia
Seem to me proper torque here would vary for which style of nut you are using. Mag wheel or tapered, and then the type of what/where (threads/contact surface) the lubricant or anti seize used.
[Re: Neil]
#3237958
06/11/24 05:11 PM
06/11/24 05:11 PM
jcc
Bitopia
I have always installed lug nuts dry. No reason to use oil or anti-seize in the dry high desert climate out here.
Well, just washing your car alone initiates galvanic action with all the different metals at play.
[Re: jcc]
#3237959
06/11/24 05:23 PM
06/11/24 05:23 PM
Posts: 20,819 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Wash your car often, or drive in the rain, and you'll find a lot of aluminum wheels will often have rust stains transferred onto the back of them from rotors or drums so water can in fact get in from the rear side. That said I have never had a lug nut, that I have installed myself, be affected enough by rust to bother with any lube. Idaho level rust you would find on a wheel stud, or inside a lug nut, is going to be so lightweight in nature that it wire brushes off with minimal effort if you even cared enough to mess with it. Have yet to see a wheel stud here that has rusted bad enough that the threads were starting to develop pitting to the naked eye. Now take a car that came from SLC Utah or the Oregon coast, ect. and the story may be far different.
[Re: jcc]
#3237972
06/11/24 07:19 PM
06/11/24 07:19 PM
Posts: 5,665 Detroit area
6PAX
Detroit area
Seem to me proper torque here would vary for which style of nut you are using. Mag wheel or tapered, and then the type of what/where (threads/contact surface) the lubricant or anti seize used. The wheels require the conical style lug nuts.
[Re: 6PAX]
#3238138
06/12/24 01:04 PM
06/12/24 01:04 PM
Posts: 19,687 north of coder
moparx
i have american torq-thrust originals [straight spoke] on the front of my charger. i made a 1/4" hub-centric spacer so the spokes would clear the calipers. the front studs were changed to longer ones with bullet noses, and the nuts are open ended with the new style bulge seat. i have them torqued to 85ftlbs with just a touch of copper anti-seize.
[Re: 6PAX]
#3238237
06/12/24 08:21 PM
06/12/24 08:21 PM
Posts: 3,262 Md.
carnut68
Md.
Seem to me proper torque here would vary for which style of nut you are using. Mag wheel or tapered, and then the type of what/where (threads/contact surface) the lubricant or anti seize used. The wheels require the conical style lug nuts. I had my Torque Thrust wheels modified to take a shank style lug nut. I thought it would be safer to run slicks with. 90- 100lbs.
America First!
