Re: Head gasket interchangeability
[Re: volaredon]
#3237693
06/10/24 02:52 PM
06/10/24 02:52 PM
Posts: 20,833 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
If nobody can confirm just take the LA gasket set to the parts store and visually compare them to the Magnum gaskets? Most parts stores should have 5.9 gaskets available.
Also post your findings that way others can find the answer if this question comes up again. A number of worthy questions on here kinda dead-end, and we never know if someone was able to resolve their problem or not,
[Re: Neil]
#3238091
06/12/24 11:08 AM
06/12/24 11:08 AM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
The gaskets are different looking but they are interchangeable, the only difference is the section where the pushrods go through but that's not really needed. Pics of the gaskets together and then placed on top of each other. All holes line up, used one is 360 Magnum, new one is 340. As you can see the 360 magnum cracked a head and hydraulic locked the cylinder and pushed the gasket out.
