Harmonic Damper SUM-C2515 #3237673
06/10/24 12:34 PM
06/10/24 12:34 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
does anyone have any experience with this harmonic damper from Summit racing.
Summit Racing™ Bracket Racer SFI Harmonic Dampers SUM-C2515
Thank you
Kiddart
Re: Harmonic Damper SUM-C2515 [Re: Kiddart] #3271462
11/20/24 02:23 PM
11/20/24 02:23 PM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
it's made by trick flow, used them a few times no complaints, haven't had an issue with balance.
